0 members (), 227 guests, and 13 robots.
#24691 04/18/03 11:57 PM
Anonymous
Unregistered
Is there any reason why ordinary stamped steel masonary boxes could not be used in a slab. This would not be a new pour, but added to an existing slab after cutting out a section, then using display receptacles with the heavy brass plate and disc cover.
Brian
#24692 04/19/03 03:11 AM
314.27 C 2002 NEC
#24693 04/19/03 12:07 PM
Ron Offline
314.27 C 2002 NEC would prevent you from placing them in the floor, but it is ok to surface mount a box on the floor.
Ron
#24694 04/20/03 10:27 AM
I istalled 7 of the Hubbell PFB1 PVC boxes. Each box requires a PFBA1 adapter. The box and adapter together cost about $18. A 3/4 inch thick terazzo floor will be installed on the slab. We will be using the SA5016 cover. They cost $53 each.
Hubbell's website for them is: http://www.hubbellnet.com/max_htm/PDF_Literature_Library/h4441.pdf
#24695 04/20/03 03:29 PM
Is something like this prohibited by current or recent versions of the NEC for "floor-up" mounting?
http://www.hubbellcatalog.com/wiring/datasheet.asp?PN=HBL6236
