Look Ma! I Did It Myself!
by renosteinke - 12/04/23 02:57 AM
Scary Looking Receptacles
by renosteinke - 12/04/23 02:46 AM
Old Computers?
by gfretwell - 11/21/23 03:45 PM
Simplify MOSFET Test With Source Measure Meter
by gfretwell - 11/18/23 09:20 PM
0 members (), 8 guests, and 46 robots.
#222232 06/01/23 03:24 PM
BigB Offline OP
My plumber needs to replace a 208 volt water heater and they are very expensive, $2,800 for a 40 gallon. I told him he can use a 240 volt unit but it will heat at 75% of what it would at 240. Why can't he buy a 240 unit and install 208V elements in it?
The best I can tell they are the same element, A 4500w becomes 3500w. That is how they show up in the catalog. Buy a 5500w 240v water heater.
BigB Offline OP
Kinda makes you wonder why they make 208 units for 7 times the cost of a 240 unit.
Because they can. Maybe they have special elements that provide full watts but I didn't see anyone bragging about selling them.
There isn't a lot in a water heater. Typically it is just a tank with 2 elements and 2 thermostats. There shouldn't be anything special about the thermostats. I know they don't like salt water when my heater went under wink
1 member likes this: BigB
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
sbi
sbi
indiana
313,328 Are you busy
239,221 Re: Forum
222,983 Need opinion
