An impossible Support Violation
by gfretwell - 09/12/23 04:29 PM
How are you Jersey folks about the windmills?
by gfretwell - 09/08/23 02:21 PM
Having trouble logging in?
by Admin - 09/01/23 10:26 AM
New TikTok Challenge Posing Serious Risks
by iTacos - 08/28/23 10:04 AM
Mis-applying Codes
by gfretwell - 08/25/23 05:31 PM
Get Back to work, Keep Using it.
1 members (Scott35), 16 guests, and 13 robots.
#222230 05/29/23 10:18 PM
Looking for suggestions: How to quickly locate a short and cause minimal damage in the process.
A mobile home energizes its metal roof whenever a certain circuit is powered up. The circuit continues to operate. There has been extensive “remodeling” performed over the years by unqualified parties. Note this is information provided to me by the customer; I have not yet surveyed the site.
The last time I was faced with this, I nearly destroyed the trailer before finding the problem. A screw holding down bath tub trim had pierced the cable.
I am open to suggestions as to both methods and equipment.
Mark all the outlets on that circuit and see which ones will de-energize the frame when disconnected. Then try to analyze how the wire is run and isolate it to one span. You could also isolate it with a meter, looking for the ground fault.
The trick is to keep cutting the circuit down until you get to one cable. It is time consuming tho unless you get lucky early.
1 member likes this: sabrown
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
CharlieE
CharlieE
Indianapolis
311,074 Are you busy
237,472 Re: Forum
221,260 Need opinion
