That's an interesting effect you noted there. I suspect that you're substantially beyond 90 degrees of phase delay and just barely above the voltage needed to feed driver output. The input impedance of each lamp would change during the seconds that it takes to charge up to the point where the LEDs are pulsed. It makes sense that they would fall into sequence and balance out, rather than all draw peak charging currents at once. Joe
