Photos of the Week:
Meter vs Bricklayer
Meter vs Bricklayer
0 members (), 184 guests, and 10 robots.
Did you ever notice birds will sit on distribution wires? The distribution wire can be found along nearly every Main Street in town on wood poles usually with three to four wires. BUT you never see birds sitting on transmission lines!
I suspect there may be 2 factors at play. At 6 digit voltages there is a corona around that wire and there also may be a lot of heat. HV lines are typically overloaded and run pretty hot. The eagles do sit on top of the poles for transmission wires.
[Linked Image from gfretwell.com]
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
watersparkfalls
watersparkfalls
Washington...Not DC
352,457 Are you busy
276,131 Re: Forum
255,636 Need opinion
