Upside Down ThreeWay
by gfretwell - 08/12/22 12:30 AM
Load Calcs for EVs and RVs
by gfretwell - 08/12/22 12:24 AM
Wiring method choice
by HotLine1 - 08/10/22 03:39 PM
NEC- 314.23 (H) (1)
by renosteinke - 08/10/22 11:13 AM
RV Forums
by gfretwell - 08/07/22 07:01 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 16 guests, and 13 robots.
#221771 06/17/22 02:42 AM
dsk Offline OP
A little warning, and it is allowed to grin
It may not be safe enough for the children of a handy person.
My son (When he was 3) solved the problem, of course he had seen me with a screwdriver. The rest of the history is up to your fantasy wink
It turned out well, but maybe someone may learn of my experience without risking to much.
To the best of my knowledge, these covers are no longer acceptable. They were frequently installed in areas that 'little ones' were the occupants, back in time. The requirement of tamper resistant receptacles within the NEC solved the issues with this type cover, and the few variations of the same type design.
Just curious; the pic is not a device used in Norway, correct?
dsk Offline OP
Right, but we had a similar suystem with our european standard, the main point is that if the child know how to use a screwdriver... its not safe.
These are still sold/used in old circuits with no grounding. (I feel pretty safe without grounding as far as it is no risk of touching any conductive surface that may lead to ground.)
In a new house alloutlets are grounded. (Schuko)
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
NickD
NickD
Amish Country, PA
BigB 5
294,988 Are you busy
226,674 Re: Forum
211,851 Need opinion
