If you test for continuity through a capacitor that won't work with an Ohmmeter.
To check the other (start) winding for continuity you need to bridge across the capacitor and see what readings you get.
Normally a run winding has a thicker gauge wire, and will have a lower ohm reading. (e.g. 12 Ohms)
A start winding has a thinner gauge of wire, and will have a higher ohm reading (e.g. 17 Ohms)
Try to do an insulation check first, and see if there is no winding short to earth (motor frame).
Check the centrifugal switch if it works. (should be closed at standstill).
That wire insulation looks brittle and may need some additional sleeving.
To do a simple testrun and see if the motor works. Connect 1 and 3 to a 110 volts supply, the earth to the exposed motor frame (safety), the motor should hum, it may sometimes even start without a start winding energized.
Switch power off !
Give the pulley a push with a stick or wrap a string around the pulley, before energizing. Pull the string, so the pulley and armature rotate, then energize the motor and see if it works.
Now test the motor with start winding.
If the start winding and capacitor is ok. connect 1 and 2 together on Active, or Phase and 3 and 4 together on the Neutral.
The motor should start and run, centrifugal switch should switch start winding off.
To change rotation of the motor, connect 1 and 4 to Active and 2 and 3 to Neutral.
That flips over the start field and the motor will run the other way
Hope it helps.
