How's all our Non-US folks doing?
by grich - 09/27/21 11:59 AM
Well I am back to stay (nearly 6 years)
by Bill Addiss - 09/26/21 11:09 PM
nec 110.3 (B)
by HotLine1 - 09/26/21 03:42 PM
Grounding electrodes
by gfretwell - 09/07/21 03:41 PM
Now you know.
Now you know.
by Tom_Horne, September 7
February, North East Indiana
by timmp, July 25
1 members (Scott35), 12 guests, and 24 robots.
WNYJim Offline OP
Whenever I've installed (or changed out) a switched receptacle I always make the bottom half switched and the top live. Thinking that a lamp would be plugged in the bottom, leaving easy access the top section.
I've often found the top half switched and it seems backwards to me.
That sounds reasonable and I do it too but I am sure someone has the opposite opinion. The code is silent on it.
iagree
That sounds like the best way to go.
I'm in agreement. If a lamp is plugged into the bottom switched half, the cord hangs down and the top half is easily accessible for non-switched access.
My 1967 home had the switched outlet on top. I changed them all over to the bottom. And always install customer switched outlets on the bottom.
Timm
Every house I ever bought had both halves of the duplex switched. It wasn't until I started wiring them myself that I had "half hots".
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Theelectrikid
Theelectrikid
Levittown, PA
timmp 3
rick99 1
283,573 Are you busy
216,870 Re: Forum
203,218 Need opinion
