12 Lead Motor Connection Weird
by Elektrik - 01/12/22 11:09 PM
Well There's your problem.
by gfretwell - 01/08/22 12:17 AM
Happy New Year!!
by HotLine1 - 01/04/22 09:50 AM
Sangamo s309.2
by Robski - 12/31/21 04:54 PM
Panel
by grich - 12/28/21 05:54 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 15 guests, and 19 robots.
#220986 09/25/20 03:07 PM
BigB Offline OP
Been patented for 5 years but thankfully no one has manufactured it https://www.mikeholt.com/newsletters.php?action=display&letterID=2223&email=bwinkle4@cox.net#comments
BigB #220987 09/26/20 12:45 AM
This also assumes nobody swapped the white and black along the way. The scary thing about that is your 3 light tester would say it was fine but the case of your drill would have 120v on it.
gfretwell #220988 09/26/20 09:35 AM
BigB Offline OP
I hadn't thought about that scenario, and we see it a lot. It reminds me of the electronics kit I had when I was a kid, it came with a radio antenna wire that had a blade on the end to plug into the neutral slot of a receptacle and use the building wiring for an antenna. The blade would only fit the wide slot on a polarized receptacle. I think about that a lot, what could have happened had someone mis-wired the receptacle. The kits were marketed to young electronics minded kids and students.
BigB #220989 09/26/20 05:31 PM
I always used the center screw on the cover, using the EGC. Back in the analog TV days you could get a decent picture on a TV with that.
Later I strung a long wire antenna to a post we installed behind the house. I wired it to my "All American" tube radio for AM DX'ing.
I would be scared to do that here because of lightning. It was pretty cool though for a kid. On a clear winter night I could get radio stations from a thousand miles away.
BigB #220990 09/26/20 08:32 PM
BigB Offline OP
Yep I would listen to AM radio from Tucson, KOMA in OK City, WLS in Chicago. I believe KOMA was 50,000 watts. Then there were the mega watt stations South of the border. I listened to the one in Monterrey a lot.
I had a 50 foot wire stretched across the roof and a little 9 volt Toshiba shortwave and I would sit on the roof at night and listen to the whole world.
BigB #220991 09/26/20 11:03 PM
Those 50KW clear channel stations were pretty easy. The trick was getting one that was more like 15-25KW and not stepped on by another station.
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Joe Tedesco
Joe Tedesco
Boston, Massachusetts USA
NORCAL 3
grich 1
287,774 Are you busy
219,973 Re: Forum
205,986 Need opinion
