ShoutChat Box
From an outsider- How does tipping work?
by NORCAL - 01/17/21 05:26 AM
Can I ask for your input?
by electure - 01/16/21 07:04 PM
Ground fault remover :-)
by NORCAL - 01/16/21 10:29 AM
Photo Editing Software?
by grich - 01/13/21 11:18 AM
Happy New Year Folks!!!
by Trumpy - 01/04/21 05:46 AM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 15 guests, and 18 spiders.
What would be the ideal solution? #220868 06/30/20 10:21 AM
F
Fleppin Offline OP
Hello,
We bought our house recently, and it was built in the 1960s. Well, the wiring too is old and has not updated since then. The original fuse, two-wire system, and metal boxes are still in place throughout the house. To reduce electrical faults, I had hired an electrician to do some electrical changes to the wiring. So the electrician suggested to add a ground wire to the back of the metal box that would ground the outlet, and later it could be replaced with a three-prong receptacle. Next, if a GFCI is installed at the starting of a series of outlets, the following receptacles would trip the GFCI if faults happen. Is this a useful grounding method for two-prong outlets? What are your thoughts on this?
Thanks!
Re: What would be the ideal solution? [Re: Fleppin] #220869 06/30/20 01:35 PM
gfretwell Offline
Your electrician is right. If there is a ground present, connecting it to the receptacle is really all you need to do but the GFCI solves the problem if that ground is compromised or non existent. It was common to use the old style Romex with the 16ga ground in the late 50s, early 60s, connected to the boxes but still installing the 2 pin receptacle. There was a thread here about that with the dates that showed up in the code. Just bear in mind most places do not adopt the new code right away.
Re: What would be the ideal solution? [Re: Fleppin] #220870 06/30/20 01:39 PM
gfretwell Offline
This is were we discussed the small ground conductor
https://www.electrical-contractor.n...ed-grounding-wire-in-nmc.html#Post220515
Re: What would be the ideal solution? [Re: gfretwell] #220915 07/20/20 11:42 PM
F
Fleppin Offline OP
Thank you!
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
MarkC10
MarkC10
CA, Inland Empire
Show All Member Profiles
Trumpy 15
NORCAL 10
273,918 Are you busy
207,672 Re: Forum
195,392 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
