ShoutChat Box
Any Woodworkers here?
by Bill Addiss - 05/10/21 11:26 PM
Do You Travel?
by Bill Addiss - 05/10/21 11:13 PM
Just be aware of this...
by gfretwell - 05/10/21 07:30 PM
Your favourite food?
by gfretwell - 05/10/21 06:13 PM
Lock-down Thread
by gfretwell - 05/10/21 06:12 PM
2020 - 2021 Winter Project
Garden 2021
0 registered members (), 13 guests, and 12 spiders.
Code Violation or just not good Practice? #220902 07/15/20 12:11 PM
Coastal Offline OP
400 Amp back to back service, 2-200 Amp main breaker panels, one panel has all the general lighting loads (all120 volt breakers) and the other all the 240 volt circuits. Residential 3000 square foot home.
Should the 120 and 240 volt loads be balanced between the two panels and would it be a code violation if they were not?
Asking for a friend.
2017 / 2014 NEC & Related Books and Study Guides
Re: Code Violation or just not good Practice? [Re: Coastal] #220906 07/15/20 06:01 PM
gfretwell Offline
I see no issue either way but balancing the 120v loads is optimal, as much as you can. 240v loads are balanced by their very nature.
Re: Code Violation or just not good Practice? [Re: Coastal] #220912 07/16/20 03:03 PM
HotLine1 Offline
I thought I jumped in here yesterday, duh.
Ditto Greg.
It comes down to a matter of workmanship, or possibly a design issue IF the house had very rigid electrical design and drawings.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
HCE727
HCE727
Delaware County, PA, USA
Show All Member Profiles
Trumpy 19
Admin 8
278,832 Are you busy
211,988 Re: Forum
199,034 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
