ShoutChat Box
120/208 gives 240? please clarify
by gfretwell - 07/15/20 06:07 PM
Code Violation or just not good Practice?
by gfretwell - 07/15/20 06:01 PM
NESC question
by gfretwell - 07/15/20 03:40 PM
Questioning the electrical norms
by HotLine1 - 07/13/20 12:40 PM
You will never guess
by BigB - 07/13/20 09:45 AM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 13 guests, and 14 spiders.
You will never guess #220829 06/05/20 05:45 PM
BigB Offline OP
why the AFCI kept tripping. New house, finishing up a few odd items today when the floor cleaners came to me and said "soon as we try to use our vacuum in the front bedroom the breaker trips" Huh, must be your vacuum, nobody else has tripped a breaker yet, so I reset the breaker and try my shop vac, trips almost immediately. This circuit has been up and running for months with no issues, lights working fine, plugs work fine except for the vacs. I swapped the breaker with another, problem stays with the circuit. Went on to do some other things so I could ponder on it a while.
Next job, owner wants the bath wall sconce flipped over in the bath that goes with this bedroom, go in there to do that when I noticed a faint humming coming from the 110 CFM exhaust fan which is COMPLETELY COVERED WITH BLUE TAPE AND CAN'T GET ANY AIR. Apparently the tilers covered it to keep dust out, or maybe it was the painters. Once the tape was removed all was well. So the fan must have been really over-amping and the vacs were enough to throw the circuit over the edge, of course first thoughts are always a wiring error or bad AFCI now days.
Just goes to show, I have learned over the years when troubleshooting not to just rush in and tear everything apart right away. It usually pays to think about it for a while and reason things out.
Re: You will never guess [Re: BigB] #220831 06/06/20 10:52 AM
BigB Offline OP
20 years ago we would have grabbed the amp clamp first thing, what I'm trying to say is the AFCIs have changed the way we think about troubleshooting, we are much more conditioned to believe we have a wiring error than an overload which can lead to wasted time.
Re: You will never guess [Re: BigB] #220832 06/06/20 04:38 PM
gfretwell Online Content
It would be nice if all AFCIs came with diagnostics, an LED that comes on for arc faults and another for ground faults.
Re: You will never guess [Re: BigB] #220837 06/12/20 03:20 AM
Trumpy Offline
BigB,
That's quite interesting, I would have suspected something like bad brushes/ commutator in the vacuum cleaner motor.
Re: You will never guess [Re: BigB] #220889 07/13/20 04:08 AM
andey Offline
That sounds very foul to me.
I looked up the first 110 CFM bathroom fan datasheed i could find and it has 0.2 amps nominal current. This would only increase a little bit covered up, if not decrease (depending on the fan design).
Where should it dispass all the heat. otherwise, it would bake the windings and hopefully trip the thermal protection.
I'm very sure there is another fault hidden somehwere in the house that tripped the AFCI.
Re: You will never guess [Re: andey] #220890 07/13/20 09:45 AM
BigB Offline OP
All I can tell you is that as soon as I uncovered the fan everything went back to normal and the owners have been in there for a month now with no issues. Maybe it wasn't an overload but some other motor related phenomena that caused it it simulate an arc fault.
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Joe Tedesco
Joe Tedesco
Boston, Massachusetts USA
Show All Member Profiles
Admin 8
267,461 Are you busy
202,089 Re: Forum
190,651 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
