ShoutChat Box
Danish type K Sockets
by dsk - 02/23/20 02:42 AM
15 amp outlets removed due to cell phones
by BigB - 02/20/20 07:23 PM
Square D "All-In-One" Panelboard
by gfretwell - 02/18/20 07:38 PM
2020 code
by shortcircuit - 02/11/20 04:30 PM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 120 guests, and 7 spiders.
Where are this kind of fuses used? #220462 01/22/20 01:04 PM
dsk Offline OP
I just got these two, and have no idea of where they should be used. If you need it you may get it.
Test Equipment:
Large Selection of Test Equipment For Electrical, HVAC, Test & Measurement
Re: Where are this kind of fuses used? [Re: dsk] #220463 01/22/20 01:09 PM
dsk Offline OP
Actually I got these too, but that must be for low voltage. (I have 15 (1 broken))
Re: Where are this kind of fuses used? [Re: dsk] #220476 01/28/20 05:03 PM
djk Offline
The first image are old style Belgian fuses for use on a distribution board in a home / office. They were common until the early 1980s.
Examples:
https://www.bricozone.be/t/ancien-fusibles.31395/
While these are made to Belgian CEBEC standards, I know there was a similar looking French system. I'm not sure if they're identical but they look rather closely related.
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
NickD
NickD
Amish Country, PA
Show All Member Profiles
dsk 9
djk 5
Admin 3
cgw 2
263,570 Are you busy
198,652 Re: Forum
187,548 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
