ShoutChat Box
2020 code
by shortcircuit - 01/20/20 10:29 AM
Low voltage fuses,where should they fit?
by dsk - 01/19/20 11:31 AM
ID strange fuses. never seen...
by dsk - 01/19/20 11:22 AM
diazed fuses
by djk - 01/18/20 05:10 PM
GFCI receptacle in kitchen
by gfretwell - 01/17/20 11:43 AM
FPE in Germany pt.2
FPE Breaker panel in germany
1 registered members (Scott35), 67 guests, and 4 spiders.
Mistake in Instructions? #220351 10/27/19 09:04 PM
BigB Offline OP
These are online instructions for a 40 amp EV charger. Note the sentence in the red box.
Re: Mistake in Instructions? [Re: BigB] #220354 10/28/19 04:19 AM
ampherder Offline
12 AWG ground on a 40 amp breaker is what is allowed in T250.122.
Re: Mistake in Instructions? [Re: ampherder] #220355 10/28/19 08:34 AM
BigB Offline OP
I see that now, I wasn't aware it had changed
Re: Mistake in Instructions? [Re: BigB] #220356 10/28/19 12:41 PM
gfretwell Offline
I understand table 250-.122 may be confusing to read but it says
Rating or Setting of
Automatic Overcurrent
Device in Circuit Ahead
of Equipment, Conduit, etc.,
Not Exceeding
(Amperes)
20 12ga copper
60 10ga copper
I read that to say if you exceed 20a and do not exceed 60a you are in a #10.
Just as a sanity check, what size is the ground in a 10ga or 8 ga cable ... 10ga
Re: Mistake in Instructions? [Re: gfretwell] #220357 10/28/19 05:51 PM
BigB Offline OP
OK yes that makes sense. They made it a bit confusing when they took out the 30 and 40 amp columns just because we were so used to seeing those numbers included but when you think about it they weren't necessary when the higher amperage columns jump from conductor size to conductor size with no repetition. So the instructions for the EV charger are incorrect.
Re: Mistake in Instructions? [Re: BigB] #220358 10/28/19 06:36 PM
gfretwell Offline
Yes the OP was right and the EV instructions were wrong.
They made the change in format to T 250.122 in the 2011 cycle but the rule didn't change.
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
The Watt Doctor
The Watt Doctor
Mont Belvieu, TX
Show All Member Profiles
Trumpy 12
dsk 5
262,437 Are you busy
197,561 Re: Forum
186,572 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
