Shout Box
Positive Ground on 125 VDC Station Batteries
by The Watt Doctor. 05/23/19 08:55 AM
2020 is at the printers.
by gfretwell. 05/22/19 10:11 AM
Chinese wire symbols?
by Texas_Ranger. 05/19/19 03:09 PM
Pool - Daisy chained GFCI
by gfretwell. 05/18/19 01:30 PM
110.26 working clearances
by HotLine1. 05/14/19 02:08 PM
What is this for?
Plug terminals
0 registered members (), 9 guests, and 15 spiders.
Page 9 of 9 1 2 3 4 5 6 7 8 9
Re: "Esoteric" countries and their wiring practices? #135328
10/26/04 06:58 AM
10/26/04 06:58 AM
Cn_HK  Offline
will Hong Kong change its...
Unsure. Safety Advisory Committee is discussing that topic.
[This message has been edited by Cn_HK (edited 10-28-2004).]
Test Equipment:
Large Selection of Test Equipment For Electrical, HVAC, Test & Measurement
Re: "Esoteric" countries and their wiring practices? #135329
10/26/04 03:32 PM
10/26/04 03:32 PM
SvenNYC  Offline OP
New York City
I think Hong Kong should stay with the existing British wiring standards.
Changing plug and wiring configurations only leads to confusion later on, especially when average folks have to start cutting off factory-molded plugs and screw new replacements on, or deal with dodgy adapters.
Re: "Esoteric" countries and their wiring practices? #135330
12/09/04 11:21 AM
12/09/04 11:21 AM
C-H  Offline
Stockholm, Sweden
Chinese sockets, in new work. The one on the left is ordinary 220V, the one on the right is 380V. According to the correspodent, the latter is better than the plug/sockets used in Europe as it allows you to swap phases easily. (I have a picture of the corresponding plug, but I think I can leave it to your imagination.)
{Edited to correct image link}
[This message has been edited by C-H (edited 12-09-2004).]
Re: "Esoteric" countries and their wiring practices? #135331
12/09/04 05:18 PM
12/09/04 05:18 PM
SvenNYC  Offline OP
New York City
C-H:
The socket on the right looks similar to our 240-volt 50 amp sockets used for stoves here, except the horizontally oriented pin is replaced by a round one, for the ground.
[This message has been edited by SvenNYC (edited 12-09-2004).]
Re: "Esoteric" countries and their wiring practices? [Re: SvenNYC] #220044
04/20/19 07:00 PM
04/20/19 07:00 PM
Texas_Ranger  Offline
Vienna, Austria
Originally Posted by SvenNYC
C-H it is ungrounded.
Korean wiring doesn't use grounds or neutrals.
It is 220 volts across hot & hot [Linked Image]
Resurrecting this ancient thread because it still seems to be popular on the web.
According to all sources I've found, the Republic of Korea (South) migrated from a US system (120/240 V, 60 Hz, NEMA plugs) to 230/400 V 60 Hz using Schuko sockets starting in the 1970s. I've seen pictures of services that clearly indicated three phases plus neutral, supporting the 230/400 V claims. Sockets are regular German Schuko but designed to cram a double into an American box.
Here's the only one I've ever seen for sale online with (sort of) English description:
https://www.ebayshopkorea.com/itm/2...Outlet-Panel-EU-220V-KOREAN/222470620152
North Korea apparently also uses Schuko sockets but the mains frequency seems to be 50 Hz.
Re: "Esoteric" countries and their wiring practices? [Re: Texas_Ranger] #220045
04/23/19 02:34 PM
04/23/19 02:34 PM
winston_1  Offline
London, UK
Originally Posted by Texas_Ranger
[quote=SvenNYC]
When I visited North Korea around 3 years ago they were using Chinese sockets.
Re: "Esoteric" countries and their wiring practices? [Re: winston_1] #220059
05/02/19 08:02 PM
05/02/19 08:02 PM
Vienna, Austria
[quote=SvenNYC]
That's quite interesting! Seems that online sources are either outdated or plain wrong!
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
electure
electure
Fullerton, CA USA
Show All Member Profiles
255,147 Are you busy
191,239 Re: Forum
180,987 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.024s Queries: 16 (0.006s) Memory: 1.0098 MB (Peak: 1.1661 MB) Zlib enabled. Server Time: 2019-05-23 17:22:49 UTC
