Shout Box
Positive Ground on 125 VDC Station Batteries
by The Watt Doctor. 05/23/19 08:55 AM
2020 is at the printers.
by gfretwell. 05/22/19 10:11 AM
Chinese wire symbols?
by Texas_Ranger. 05/19/19 03:09 PM
Pool - Daisy chained GFCI
by gfretwell. 05/18/19 01:30 PM
110.26 working clearances
by HotLine1. 05/14/19 02:08 PM
What is this for?
Plug terminals
0 registered members (), 16 guests, and 16 spiders.
Page 14 of 14 1 2 12 13 14
Re: Norwegian power? [Re: Meadow] #219218
03/30/18 08:10 AM
03/30/18 08:10 AM
dsk  Offline
Norway
Things takes time, the building process is not finished yet, and the cable are still running trough the house. :-)
dsk
Test Equipment:
Large Selection of Test Equipment For Electrical, HVAC, Test & Measurement
Re: Norwegian power? [Re: Meadow] #219567
08/28/18 02:54 PM
08/28/18 02:54 PM
dsk  Offline
Norway
They has had proffesionals there now, and the cables are now propery put in the ground with the right kind of cable, and terminations.
2018-08-18 11.00.33.jpg (44 downloads)
Re: Norwegian power? [Re: Meadow] #220040
04/19/19 10:29 AM
04/19/19 10:29 AM
dsk  Offline
Norway
I am wondering how they will do it, but someone was telling me that they want to convert the area from 230V TT to 400/230 TNC-S
My guess will be a transformer with both voltages, and dirstibution of of the 400V system to new houses.
Re: Norwegian power? [Re: Meadow] #220043
04/20/19 06:27 PM
04/20/19 06:27 PM
Texas_Ranger  Offline
Vienna, Austria
They could convert the existing buildings too, it'd take new cables and some inside work too. I guess a dual-voltage transformer wouldn't be enough for running both systems in parallel since the old setup requires a floating star point (IT) while the new one needs an earthed one (TN).
Re: Norwegian power? [Re: Meadow] #220050
04/26/19 03:56 AM
04/26/19 03:56 AM
dsk  Offline
Norway
The old system is a TT system so it will probably be OK, In the neighborhood they even have a transformer with 2 separate secondary winding's too.
dsk
Re: Norwegian power? [Re: Meadow] #220058
05/02/19 08:01 PM
05/02/19 08:01 PM
Vienna, Austria
I suppose they could convert the older parts to 133/230 V TT if they're currently 133/230 IT with earthed local PE. That'd be the Belgian system, once common in quite a few European countries. They'd still need a transformer with separate secondaries I guess. If all existing supplies are single phase (i.e. only two out of the three phases are supplied, giving 230 V) they could replace the distribution and reconnect the existing buildings to 230 V line to neutral instead.
Re: Norwegian power? [Re: Meadow] #220062
05/03/19 04:30 AM
05/03/19 04:30 AM
dsk  Offline
Norway
It is already 133/230 TT, so I guess that is the way they will do it.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
electure
electure
Fullerton, CA USA
Show All Member Profiles
255,144 Are you busy
191,238 Re: Forum
180,987 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.031s Queries: 17 (0.008s) Memory: 1.0048 MB (Peak: 1.1667 MB) Zlib enabled. Server Time: 2019-05-23 17:00:57 UTC
