Shout Box
Light activation in closet by a broken connection?
by geoff in UK. 02/19/19 01:35 PM
AFDD's coming to the UK
by Texas_Ranger. 02/18/19 02:04 PM
Israel
by Texas_Ranger. 02/18/19 02:01 PM
250.104
by gfretwell. 02/16/19 01:08 PM
What is this for?
Plug terminals
0 registered members (), 20 guests, and 14 spiders.
Delta Electronics Recalls Solar Inverters #219935
02/08/19 08:32 AM
02/08/19 08:32 AM
Admin  Offline
NY, USA
Delta Electronics Recalls Solar Inverters Due to Fire and Impact Hazards:
Recall Date: February 7, 2019
Recall Number: 19-061
Recall Summary
Name of Product:
Eltek solar inverters
Hazard:
The capacitors can fail and allow heat to build up and the cover can eject with force from the unit, posing fire and impact hazards.
Remedy: Replace
Consumers should immediately stop using the recalled inverters, turn off the switch on the inverter’s front cover, switch off the circuit breaker for the inverter and contact Delta Electronics USA to arrange for a free replacement inverter. Delta Electronics will remove the recalled inverter and install a replacement.
Consumer Contact:
Delta Electronics toll-free at 888-770-7142 from 7 a.m. to 6 p.m. CT Monday through Friday or online at www.eltek.com
and click on “Product Recall” for more information
Pictures available here: https://www.cpsc.gov/Recalls/2019/D...Inverters-Due-to-Fire-and-Impact-Hazards
Recall Details
Units:
About 2,600
Description:
This recall involves the Eltek THEIA HE-t string inverters that convert DC power from residential solar panels to AC power supplied to the electrical grid system. The recalled inverters measure about 28 inches high by 14 inches wide by 6.5 inches deep. They were sold in four different kilowatt ratings: 2.0 kW, 2.9 kW, 3.8, kW, and 4.4 kW. “Eltek,” and the model designation “THEIA” and “HE-t” are printed on the front display panel of the inverter. The inverters could be installed in different places in consumers’ homes.
Incidents/Injuries:
Delta Electronics has received 11 reports of the capacitors failing and allowing heat buildup, including two reports of the cover forcibly ejecting off the inverter units. No injuries have been reported.
Sold At:
Through various solar installers in Arizona, New York, Tennessee and Washington from March 2012 through May 2017 for between $2,000 and $4,000.
Importer(s):
Delta Electronics USA Inc., of Plano, Texas
Manufactured In:
China
Re: Delta Electronics Recalls Solar Inverters [Re: Admin] #219936
02/08/19 01:23 PM
02/08/19 01:23 PM
HotLine1  Online Content
Brick, NJ USA
Gee it's funny that this posting says 'made in China' and the pic of the mfg label states...' Made in USA'
Interesting??
I just noticed that thru the link.
Re: Delta Electronics Recalls Solar Inverters [Re: HotLine1] #219943
02/10/19 03:51 PM
02/10/19 03:51 PM
Admin  Offline
NY, USA
Interesting??
Strange, I didn't notice that...
dunno
Re: Delta Electronics Recalls Solar Inverters [Re: Admin] #219951
02/13/19 10:26 AM
02/13/19 10:26 AM
electech  Offline
Northern Il
Haven't posted in a while....
At my company we are very careful with our "Made in" claims. When in doubt, I push an "Assembled in" label. If your product has a circuit board full of electronic parts, it's nearly impossible to make a credible "Made in USA" claim. Reaching the "all or virtually all" threshold on content is going to be difficult, and even then you have to watch your sourcing on an ongoing basis.
(I make no claims concerning this manufacturer's claim...)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Bill Addiss
Bill Addiss
NY, USA
Show All Member Profiles
Admin 9
253,265 Are you busy
189,895 Re: Forum
179,608 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.021s Queries: 15 (0.004s) Memory: 0.9635 MB (Peak: 1.0966 MB) Zlib enabled. Server Time: 2019-02-20 14:01:59 UTC
