Shout Box
New fan motor for Panasonic
by HotLine1. 06/25/19 03:53 PM
Burning out of return(white) side of 120volt rec
by crselectric. 06/14/19 02:15 AM
Video door bell causing chime activation of coil
by JoeTestingEngr. 06/13/19 12:43 PM
Troubleshooting Voltage Drop Across Relay
by gfretwell. 06/09/19 11:49 AM
Apple Recalls Three-Prong Wall Plug Adapters
by Admin. 06/05/19 09:06 PM
What is this for?
Plug terminals
0 registered members (), 13 guests, and 9 spiders.
Residential Smoke wiring #219892
01/07/19 10:46 AM
01/07/19 10:46 AM
Steve Miller  Offline OP
Bruceton Mills, WV
We have always advocated wiring the smokes to a local lighting circuit. The thinking is that if the breaker trips, you'll know it. You may not know it if a dedicated smoke circuit trips. Example being ... residents are on vacation and a surge or short outage causes the breaker to trip. After a week or so the batteries are dead and the residents return unaware of the lack of protection. The question: (I have no access to NFPA 72) is this code or just something we have always done?
Re: Residential Smoke wiring [Re: Steve Miller] #219897
01/08/19 02:56 PM
01/08/19 02:56 PM
HotLine1  Offline
Brick, NJ USA
A quick discussion with my Fire Official results in:
Yes, the smokes on a circuit with a light (luminaire) WAS the chosen way, back 20-25 years.
NOW, a dedicated circuit is required. It's in "72", but neither one of us has the time to hunt it down.
BTW, Bob has 40+ years in Fire.
Re: Residential Smoke wiring [Re: Steve Miller] #219898
01/08/19 03:00 PM
01/08/19 03:00 PM
Bruceton Mills, WV
Thanks
Re: Residential Smoke wiring [Re: Steve Miller] #219903
01/10/19 08:55 AM
01/10/19 08:55 AM
HotLine1  Offline
Brick, NJ USA
Steve
Documentation I have access to (Thanks Bob) is as follows:
NJ IRC 2015......R314.6 .....Wiring shall be permanent, and without a disconnecting switch other than those required for overcurrent protection.
2013 National Fire Alarm & Signaling Handbook Chapter 29
Basically says a good practice is to use a branch circuit that supply a lighting circuit.....Further into that text it alludes that some states & locals may require a dedicated circuit, consult AHJ. (Not complete text, as I am not a typist.)
Seems like a round about way of saying 'either or'; however here it is a dedicated circuit.
Re: Residential Smoke wiring [Re: Steve Miller] #219904
01/11/19 01:36 AM
01/11/19 01:36 AM
gfretwell  Online Content
Estero,Fl,usa
Put it on the circuit with the Wi Fi router. They will track down the fault right away. wink
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
sbi
sbi
indiana
Show All Member Profiles
Admin 2
Khombo 2
255,884 Are you busy
191,858 Re: Forum
181,623 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.019s Queries: 15 (0.004s) Memory: 0.9693 MB (Peak: 1.1117 MB) Zlib enabled. Server Time: 2019-06-27 10:31:46 UTC
