Shout Box
Ronald and Nancy Reagan in GE commercials
by Bill Addiss. 03/13/19 08:12 PM
Carflex in an RNC connector?
by gfretwell. 03/12/19 05:21 PM
Reverse-feeding transformer in PV system?
by HotLine1. 03/11/19 08:37 AM
Vintage stage lighting and equipment catalogs
by Albert. 03/09/19 06:21 PM
TJX Recalls Heating Pads
by Admin. 03/08/19 09:33 PM
What is this for?
Plug terminals
0 registered members (), 9 guests, and 8 spiders.
Re: Video door bell causing chime activation of coil [Re: crselectric] #219825
11/30/18 08:37 PM
11/30/18 08:37 PM
gfretwell  Online Content
Estero,Fl,usa
You could disconnect the wires at the smart button and see what you have then (assuming this is just a doorbell circuit)
Usually the power goes into the chime and they run a switch loop to the button. You should be able to ring the chime straight from the transformer leads. If that doesn't work you have a bad transformer or a bad chime.
I suppose you really should find the transformer and remove it if it is bad or at least remove power from it if it is hanging outside a box, buried in the wall and find an accessible place for a new one.
Study Guides for VDV / Structured Cabling Installers
Voice, Data, Video, (VDV) Fiber Optics, Communications, Low Voltage,
Fire Alarm, Electronic Security Systems Installations & Related
NTC Low Voltage Training & NICET Exam Study Guides
Re: Video door bell causing chime activation of coil [Re: crselectric] #219839
12/06/18 03:17 AM
12/06/18 03:17 AM
Trumpy  Offline
SI,New Zealand
Is there any chance that the chime wiring has been run in parallel with higher voltage cables, causing an induced voltage at times?
Re: Video door bell causing chime activation of coil [Re: crselectric] #219841
12/08/18 04:19 PM
12/08/18 04:19 PM
crselectric  Offline OP
albany, ca
So got into attic seems to be older type install with individual conductors run to each device, typical of older system installed with knob and tube era, where trans former is spliced off K&T wires and nailed to side of joist,
Re: Video door bell causing chime activation of coil [Re: crselectric] #219845
12/10/18 01:35 AM
12/10/18 01:35 AM
Estero,Fl,usa
What are the chances you can just run fresh wire or use the existing with a regular transformer.
Re: Video door bell causing chime activation of coil [Re: crselectric] #219848
12/16/18 03:12 PM
12/16/18 03:12 PM
albany, ca
So rewired the chime and located new transformer in accessible attic, got 16 volt trans, read 20.4 at button contacts, chime still only strikes once, on front contact. could the chime be blown since only receiving 13 volts over time?
Re: Video door bell causing chime activation of coil [Re: crselectric] #219849
12/16/18 10:01 PM
12/16/18 10:01 PM
Estero,Fl,usa
Is there a terminal for one chime and another for both?
Did you test the chime with the new transformer directly connected?
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Radar
Radar
Los Angeles, CA
Show All Member Profiles
Admin 11
Albert 3
253,877 Are you busy
190,314 Re: Forum
180,026 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.021s Queries: 16 (0.005s) Memory: 0.9957 MB (Peak: 1.1464 MB) Zlib enabled. Server Time: 2019-03-21 06:06:29 UTC
