Shout Box
Electrical services in the South Puget Sound
by cambridgeelectri. 01/22/19 02:33 AM
LED retrofit flickers
by rmiell. 01/18/19 08:49 PM
Israel
by Texas_Ranger. 01/14/19 07:12 AM
Free Code class in Maryland 1/16/2019
by Admin. 01/12/19 05:43 PM
Calling all Non-US members!! (Non-US only)
by RODALCO. 01/12/19 02:37 AM
What is this for?
Plug terminals
0 registered members (), 6 guests, and 15 spiders.
Single phase and what you call it. #219479
07/30/18 08:18 PM
07/30/18 08:18 PM
gfretwell  Offline
Estero,Fl,usa
Does anyone else have problems when they hear people call 120/240 1p "split phase" or even "2 phase"?
Yikes it sets my teeth on edge.
The problem is even Wikipedia and a few panel manufacturers use the term split phase in their documentation.
Split phase is one way to wire a motor and there is only one phase in your household panel with 2 ungrounded conductors derived from one 240v secondary that just happens to have a grounded center tap. It is simply single phase, nothing else.
... or am I just being too pedantic?
Re: Single phase and what you call it. [Re: gfretwell] #219480
07/31/18 05:36 PM
07/31/18 05:36 PM
twh  Offline
Regina, Sask.
What do you think of the term "three-way switch?"
What bugs me is putting the question mark inside the last quotation mark.
Re: Single phase and what you call it. [Re: gfretwell] #219482
08/01/18 11:55 AM
08/01/18 11:55 AM
HotLine1  Offline
Brick, NJ USA
Greg:
Here is a link to "2 phase", courtesy of Scott35
https://www.electrical-contractor.n...&Number=148672&page=3#Post148672
It's buried in the Tech area.
Re: Single phase and what you call it. [Re: gfretwell] #219483
08/01/18 11:57 AM
08/01/18 11:57 AM
HotLine1  Offline
Brick, NJ USA
I saw this only once, many, many years ago as a helping hand with one of the 'old timer' ECs in Philadelphia.
It was different, and scary back then.
Re: Single phase and what you call it. [Re: gfretwell] #219485
08/02/18 08:18 PM
08/02/18 08:18 PM
sparkyinak  Offline
Alaska
If I'm not mistaken, it was used with street cars mainly back in the day. Not sure how or it's practicality
Re: Single phase and what you call it. [Re: gfretwell] #219486
08/02/18 09:17 PM
08/02/18 09:17 PM
gfretwell  Offline
Estero,Fl,usa
Maybe somewhere but I think the streetcars in DC used 600vdc, picked up with a "plow" and the return was the track.
Re: Single phase and what you call it. [Re: gfretwell] #219487
08/03/18 01:12 PM
08/03/18 01:12 PM
HotLine1  Offline
Brick, NJ USA
I know it was not on any streetcars, it was n a house of worship in Center City. A sub-basement, way down below grade, and that made it scarier. Heck, if there was any issue, noone would have found us.
Re: Single phase and what you call it. [Re: gfretwell] #219616
09/11/18 08:38 PM
09/11/18 08:38 PM
BigB  Offline
Tucson, AZ USA
How about "It's a two way switch" or calling a 4 gang a "four way" or when the electricity stops it's a "short" or "I need two-twenty" or "I need a 200 volt upgrade"
Re: Single phase and what you call it. [Re: gfretwell] #219617
09/12/18 04:44 AM
09/12/18 04:44 AM
sparky  Offline
I found this dictionary , but it appears in need of some updating>>>
Phase.
In wave motion, oscillating motion, simple harmonic motion, or similar
periodic phenomena, the interval of time passed from the time the moving
particle moved through the middle point of its course to the instant
when the phase is to be stated
~S~
Re: Single phase and what you call it. [Re: BigB] #219749
11/07/18 01:05 AM
11/07/18 01:05 AM
Albert  Offline
Falls Church, VA
Or the fact that in plumbing, an "open" valve allows flow and a "closed" valve stops it, while for electrical switches it's the opposite!
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Show All Member Profiles
Trumpy 4
BigB 3
252,810 Are you busy
189,612 Re: Forum
179,274 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.039s Queries: 16 (0.006s) Memory: 1.0262 MB (Peak: 1.2076 MB) Zlib enabled. Server Time: 2019-01-22 12:35:14 UTC
