Shout Box
Electrical services in the South Puget Sound
by cambridgeelectri. 01/22/19 02:33 AM
LED retrofit flickers
by rmiell. 01/18/19 08:49 PM
Israel
by Texas_Ranger. 01/14/19 07:12 AM
Free Code class in Maryland 1/16/2019
by Admin. 01/12/19 05:43 PM
Calling all Non-US members!! (Non-US only)
by RODALCO. 01/12/19 02:37 AM
What is this for?
Plug terminals
0 registered members (), 6 guests, and 15 spiders.
Installing a small swimming pool #219739
10/29/18 12:06 AM
10/29/18 12:06 AM
ChrisFuller  Offline OP
Toronto, Canada
Hi, I am not an electrician, just looking for some advice please - thanks. I am looking at putting a small swimming pool in an industrial unit to open a swim school. The existing RCD board is currently in zone 1 and has lots of surface mounted cabling serving the existing lights etc, some also in zone 1. The landlord doesn’t want the RCD to be moved. Is it possible to create an enclosure which would put the RCD and associated cabling into a safe zone or even out of the pool room altogether?
I just want to be safe and not harm any of my students who come to learn swimming. I will be calling an elecrical repair service to make it done if ever it is possible.
Thanks for your help.
Re: Installing a small swimming pool [Re: ChrisFuller] #219740
10/29/18 01:47 PM
10/29/18 01:47 PM
HotLine1  Online Content
Brick, NJ USA
I suggest that you contact a local Licensed Electrical Contractor!
Also, you may need plans from a local Licensed Engineer/Design Professional as IF you were proposing to do what you state here in NJ, you would need plans by a Lic. Professional.
I will leave this thread open for one of Canadian members to comment.
Re: Installing a small swimming pool [Re: ChrisFuller] #219741
10/30/18 10:42 PM
10/30/18 10:42 PM
TimothyHallam  Offline
Toronto, Canada
I think you should contact a professional for this and then he may guide you after having a look at the location
Re: Installing a small swimming pool [Re: ChrisFuller] #219784
11/26/18 05:57 AM
11/26/18 05:57 AM
Dillow  Offline
Raleigh, NC
What did you end up doing, Chris? I'm planning something similar in the Spring and I'm wondering if this can be done on my own or do I have to consult a professional.
Re: Installing a small swimming pool [Re: ChrisFuller] #219786
11/26/18 12:50 PM
11/26/18 12:50 PM
Brick, NJ USA
Dillow:
Just an FYI; this forum is NOT a solution to any DIY projects. Your profile states that you are an electrician.
The best and only advice that can be presented is to contact a qualified electrical contractor, that is licensed and insured in your area.
DIY for any type of swimming pool is not recommended by anyone here.
I am locking this thread as of now.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Show All Member Profiles
Trumpy 4
BigB 3
252,810 Are you busy
189,612 Re: Forum
179,274 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.020s Queries: 15 (0.004s) Memory: 0.9687 MB (Peak: 1.1077 MB) Zlib enabled. Server Time: 2019-01-22 13:22:46 UTC
