0 members (), 165 guests, and 59 robots.
Vornado Air Recalls Cribside Space Heaters Due to Fire and Burn Hazards
Recall Date: January 31, 2018
Recall Number: 18-088
Recall Summary
Name of Product:
Sunny CS (cribside) nursery space heaters
Hazard:
A broken motor mount can allow the electric heating element to come in contact with the interior plastic materials and ignite, posing fire and burn hazards.
Remedy: Replace
Consumers should immediately stop using the recalled space heaters, unplug them and contact Vornado for instructions on how to receive a free replacement unit, including free shipping.
Consumer Contact:
Contact Vornado toll-free at 844-202-7978 from 8 a.m. to 5 p.m. CT Monday through Friday or online at www.vornado.com and click on the recall graphic in the lower right corner of the homepage for more information.
Pictures available here: https://www.cpsc.gov/Recalls/2018/V...ace-Heaters-Due-to-Fire-and-Burn-Hazards
Recall Details
Units:
About 5,000 in the U.S. (In addition, about 100 were sold in Canada.)
Description:
This recall involves Vornado Sunny CS (cribside) model EH1-0090 electric space heaters. They were sold in white with an accent of melon and gray colors. The heaters measure approximately 12 inches high, 8 inches deep and 11 inches at the base. The controls are mounted in a soft touch panel on the top of the unit with a multi-color display in the center of the control panel. “Vornadobaby” is printed on the side of the heater. The Vornado logo is printed on the front center of the unit. The model/type “SUNNY CS EH1-0090” and serial number are printed on a silver decal on the bottom of the unit under the elastic cord wrap. The recalled heaters have the numbers 1 and 7 as the fourth and fifth digits of the serial number (XXX17-XXXXXX).
Incidents/Injuries:
Vornado has received five reports of the electric heaters catching on fire. No injuries or property damage have been reported.
Sold At:
Bed Bath & Beyond, buybuy Baby and other stores nationwide and online at Amazon.com, Target.com, Vornado.com and other websites from October 2017 through December 2017 for about $100.
Importer(s):
Vornado Air LLC, of Andover, Kan.
Distributor(s):
Manufactured In:
China
Yeah, that's quite disturbing given the target market. eek
Here in Australia (and Europe) our fan heaters from reputable manufacturers (Kambrook, De'Longhi etc.) use much stronger frames which won't break this easily. (Although I'm quite sure there's not such a difference among the cheap generics which of course typically use the same casings worldwide; just with different elements, fan motor, and cord basically.)
Admin
Admin
NY, USA
dsk 1
556,944 Are you busy
431,755 Re: Forum
401,133 Need opinion
