Shout Box
by gfretwell. 02/16/19 01:08 PM
PurpleAir Recalls Power Supply Units
by Admin. 02/14/19 08:43 PM
Utility Company Programs
by katty81. 02/14/19 11:11 AM
AFDD's coming to the UK
by Trumpy. 02/14/19 12:29 AM
Delta Electronics Recalls Solar Inverters
by electech. 02/13/19 10:26 AM
What is this for?
Plug terminals
0 registered members (), 3 guests, and 11 spiders.
2018 Code Explained #219103
01/24/18 08:25 AM
01/24/18 08:25 AM
Potseal  Offline OP
Saskatchewan
Just recieved a copy of the 2018 CEC the other day at work. I inquired if we code get a copy of the 2018 Code Explained to go with. Lot of really good information that sheds light on certain code rules. Anybody else typically buy both?
A malfunction at the junction
Dwayne
Re: 2018 Code Explained [Re: Potseal] #219104
01/24/18 03:47 PM
01/24/18 03:47 PM
twh  Offline
Regina, Sask.
I had one some years back and I'll never get another.
Re: 2018 Code Explained [Re: Potseal] #219105
01/24/18 05:48 PM
01/24/18 05:48 PM
brsele  Offline
Northern Ontario
In Ontario we use the OESC and the new version won't be out until 2019. Then I'll take a course from the ESA to learn the changes.
So, anything interesting that I have to look forward to?
Re: 2018 Code Explained [Re: Potseal] #219147
02/13/18 11:06 PM
02/13/18 11:06 PM
gfretwell  Offline
Estero,Fl,usa
I used to buy the NEC "handbook" essentially what you are talking about but I haven't had one for several cycles. I still refer to it on things that haven't changed tho.
Re: 2018 Code Explained [Re: twh] #219150
02/14/18 03:13 PM
02/14/18 03:13 PM
Potseal  Offline OP
Saskatchewan
Curious as to why?
I found that certain code rules were explained in far greater detail and some others included examples of calculations, etc.
Dwayne
Re: 2018 Code Explained [Re: brsele] #219151
02/14/18 03:16 PM
02/14/18 03:16 PM
Potseal  Offline OP
Saskatchewan
I thought Section 10 was supposed to have a lot of changes. A first glance I didn't notice anything exceptional. I believe all changes have a triangle symbol next them? I will look again when I'm back at work (currently taking some vacation time).
Dwayne
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Alan Belson
Alan Belson
Mayenne N. France
Show All Member Profiles
Admin 7
BigB 3
253,218 Are you busy
189,874 Re: Forum
179,574 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.030s Queries: 15 (0.006s) Memory: 0.9766 MB (Peak: 1.1264 MB) Zlib enabled. Server Time: 2019-02-17 18:02:03 UTC
