Shout Box
Changing a Bulb
by gfretwell. 07/14/18 03:12 PM
Tray cable?
by gfretwell. 07/11/18 10:18 PM
Eaton Heavy Duty 30A and 60A Safety Switches
by Admin. 07/11/18 09:49 PM
ORTOVOX Recalls Avalanche Transceivers
by Admin. 07/11/18 09:44 PM
Tingle off the water spigot
by gfretwell. 07/08/18 12:58 PM
Plug terminals
Housebilding DIY wiring
0 registered members (), 23 guests, and 17 spiders.
Blackened bare copper in panel ? #218819
10/25/17 12:09 PM
10/25/17 12:09 PM
Lectricfishrman  Offline OP
Va.
Recently a home inspector noted the exposed copper grounds and the stripped ends on copper conductors were black or tarnished inside the panel ? First thought I had was chinese drywall issue but no other issues in the home . I we looked deeper the home is about 10-12 y.old and the only thing that was strange was if the soil outside may be leaching some sort of corrosive gas thru the underground feeder power riser to the meterbase ? The panel is back to back with it and the ground wire to the grounding rod was clean as it entered the bay below the meterbase but blackened once it was in the panel ? Has anyone ever experienced anything like this ? Thank you in advance for responses.
Re: Blackened bare copper in panel ? [Re: Lectricfishrman] #218820
10/25/17 04:13 PM
10/25/17 04:13 PM
gfretwell  Offline
Estero,Fl,usa
It is still probably sulfur in the air. The good news is it really seems pretty harmless in spite of all of the hysteria.
Re: Blackened bare copper in panel ? [Re: Lectricfishrman] #218821
10/25/17 04:43 PM
10/25/17 04:43 PM
gfretwell  Offline
Estero,Fl,usa
It looks like Virginia did have some Chinese drywall problems and 2005 (12 years ago) would put that house in the right time frame
Here are some things I found when I was inspecting drywall problems here in Florida (ground zero for the problem)
http://gfretwell.com/ftp/Chinese%20Drywall/devices.html
The whole gallery is here (use your back button to exit each pictures)
Once the smell goes away and the sulfur dissipates it is very possible that they cleaned up all of the evidence and they may have actually replaced some or most of the drywall, so it is possible that you are looking at a drywall house and they just did not do anything about cleaning up the panel.
I would call it no big deal but as a buyer I still might want a break on the price unless they told me a really good story.
I do know a guy who was rehabilitating these houses but he went back to the FEPAC removing every bit of the drywall, sealing the block and started over. (new carpet, new cabinets, new plumbing fixtures, all devices were replaced etc)
That was probably more than was necessary but he wanted a clear conscience when he sold the house.
Re: Blackened bare copper in panel ? [Re: Lectricfishrman] #218822
10/26/17 10:22 AM
10/26/17 10:22 AM
Va.
Does anyone have a suggestion on how to remove the tarnish safely. Thank you your inputs.
Re: Blackened bare copper in panel ? [Re: Lectricfishrman] #218823
10/26/17 10:30 AM
10/26/17 10:30 AM
gfretwell  Offline
Estero,Fl,usa
If you have enough free conductor, cut off the exposed part, strip and re terminate.Other than esthetics, it is really not a problem. It does invoke thoughts of chinese drywall tho. On the bare grounds, steel wool will work, the finer grade the better.
Re: Blackened bare copper in panel ? [Re: Lectricfishrman] #218831
10/29/17 11:18 AM
10/29/17 11:18 AM
Potseal  Offline
Saskatchewan
Haven't seen it at the panel but I ran into it out in the field at receptacles and switches in one area of a hospital ward. If you pulled a receptacle out at the west or east end of the ward the copper was fine. But in between those two areas I found several where the copper was blackened. Assumed it was a reaction to cleaning chemicals used on equipment in that area.
A malfunction at the junction
Dwayne
Re: Blackened bare copper in panel ? [Re: Lectricfishrman] #218838
11/04/17 12:16 PM
11/04/17 12:16 PM
twh  Offline
Regina, Sask.
Hydrogen sulfide around oil processing equipment turns copper black over night. The solution was to use insulated ground wire and paint exposed terminations, like on ground rods, with glyptol.
Re: Blackened bare copper in panel ? [Re: Lectricfishrman] #218960
12/31/17 11:17 PM
12/31/17 11:17 PM
Trumpy  Offline
SI,New Zealand
Are you sure this isn't moisture ingress?
Copper turns green (verdigris) then black with moisture exposure and can be a mode of conductor failure over time.
I use bootlace ferrules on all of my terminations these days, so that there is no real exposed copper.
Re: Blackened bare copper in panel ? [Re: Lectricfishrman] #219004
01/10/18 08:35 AM
01/10/18 08:35 AM
andey  Offline
germany
There is another possible cause and that's a bad chemical mix in the PVC. I believe that mostly black PVC is affected.
Stripping these won't help, the copper is black on the full length.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
noderaser
noderaser
Portland, Oregon, United States
Show All Member Profiles
Admin 5
248,155 Are you busy
185,623 Re: Forum
174,972 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.024s Queries: 15 (0.003s) Memory: 1.0048 MB (Peak: 1.1755 MB) Zlib enabled. Server Time: 2018-07-21 19:26:13 UTC
