0 members (), 543 guests, and 14 robots.
#218724 09/01/17 04:31 PM
Hi all, couple questions regarding hot tubs; this particular hot tub is located on a concrete deck and is sunken into concrete(basically it is built in the concrete) and has remote heater and pump motors, and 1 wet niche. First question is about comfort heaters they have on deck: does 680.27 (C) (1) apply to my installation? Mine seems to start in Part IV specic to hot tub, just seems like some of part II should/would apply to my install, however 680.40 specifically says only parts I & IV.
Thanks,
H2O
Workgear for Electricians
watersparkfalls #218726 09/01/17 08:43 PM
680.42 Outdoor Installations. A spa or hot tub installed
outdoors shall comply with the provisions of Parts I and II
of this article, except as permitted in 680.42(A) and (B),
that would otherwise apply to pools installed outdoors
watersparkfalls #218729 09/04/17 03:28 PM
Thanks gfretwell smile
watersparkfalls #221636 11/02/21 02:36 AM
Q
If it is a hot tub like this https://www.aquawarehouse.co.uk/, Parts I and II should be used. 680.42 is majorly for outdoor pool installation
