Hi guys,
short question:
As seen from neutral, the phase shift between A and C Phase (low legs) is 180 degrees.
However, the phase shift between A B C for running a 3ph Motor is still 3x 120 degrees? Is that correct?
I am having a hard time understanding that A and C are 180° apart seen from ground, but 120° apart seen from B.
Thanks
Greetings from Germany
Andy
