Photos of the Week:
Meter vs Bricklayer
Meter vs Bricklayer
0 members (), 66 guests, and 14 robots.
Just carious. If I had running data from with the primary or secondary side of a transformer, can the other side be calculated based off of the transformer data plate or perhaps other data?
Volt-amps in = volt-amps out + losses.
It is calculating those "losses" that separate electricians from engineers. wink
twh Offline
My guess is the losses are I squared x R, calculated for the line side and the load side. I don't think the hum uses much power.
There's also the losses in the transformer laminations. Better quality steel would have lower losses, but would be more expensive. The transformer would not get as hot while it is powered but unloaded. Probably less hum.
If Scott stops by I am sure he can tell us about a whole lot of things that affect "loss" in a transformer. I have bumped around the edges of this stuff but just enough to understand this is more than 2 coils of wire and a core when you get down to the nitty gritty of the difference between the "goesinna" and the "comesoutta". The only thing I know is the loss ends up being mostly heat so the temp this thing runs at is a pretty good clue about the efficiency.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
sparky66wv
sparky66wv
West Virginia
352,425 Are you busy
276,112 Re: Forum
255,624 Need opinion
