ShoutChat Box
Lock-down Thread
by BigB - 03/02/21 08:08 PM
Questioning the electrical norms
by Texas_Ranger - 03/02/21 05:21 PM
Northern Tool Recalls Powerhorse Generators
by Admin - 02/25/21 09:49 PM
You will never guess
by gfretwell - 02/25/21 07:48 PM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 17 guests, and 18 spiders.
Hooking up bath fan/light #217530 08/24/16 06:39 PM
Lasalle Offline OP
Hi: I am trying to install a bath fan...
Hi: I am trying to install a bath fan light fixture. Upon taking out the old one, I stupidly did not take a pic of the wiring. What I have is a 3(+ ground) cable and a 2 wire cable in the ceiling. The fixture is wired to a 2 rocker wall switch. I have tried numerous combos of wires and cannot get itright. The fixture has 4 wires- 1 blue 1 white light and power wires 1 black 1 white.Anyone have an idea how to wire this so both switches work?
Re: Hooking up bath fan/light [Re: Lasalle] #217531 08/24/16 08:28 PM
HotLine1 Offline
There should be mfg instructions and wiring diagram in the boxwith the fan.
Basic 'ringing' out the wiring will solve the situation..
Forum policy is not to provide information to the general public. You may be better off locating a local licensed electrical contractor.
Re: Hooking up bath fan/light [Re: Lasalle] #217533 08/24/16 09:53 PM
gfretwell Offline
If things are as they should be. the 3 wire cable goes to the switch, you feed the black from the 2 wire cable to the white in the 3 wire and the other 2 are the switches coming back.
They go to the blue and black wires in the fan/light. The white from the 2 wire cable goes to the whites in the fan.
Open the switch box to confirm that the white actually feeds both switches.
Those "hot" whites in the 3 wire cable should be reidentified to some other color with tape.
Re: Hooking up bath fan/light [Re: Lasalle] #217535 08/25/16 10:48 AM
BigB Offline
The two wire might also be tied in with the light to power a second light like the wall light over the vanity. Yes normally the 3 wire would be in the first light but if a remodel happened or the sparky just did it different it could be that way.
Another scenario is that the three wire may be the line in with a switch loop back although to switch both individually would have required improper use of the grounding conductor (which is common in DIY installations).
An electrician would be able to figure this out in a couple of minutes as Hotline suggested. Trial and error wiring methods are risky at best.
Re: Hooking up bath fan/light [Re: Lasalle] #217536 08/25/16 02:48 PM
HotLine1 Offline
"Trial and error wiring methods are risky at best."
Hence, my comment.
Re: Hooking up bath fan/light [Re: Lasalle] #217537 08/25/16 04:37 PM
gfretwell Offline
That is why I suggested looking in the box with the switch to verify the wire colors and as a sanity check that you are looking at the right cable.
Re: Hooking up bath fan/light [Re: Lasalle] #217538 08/25/16 09:25 PM
HotLine1 Offline
Greg:
Please....do not think I have any issue with your comments.
I thought of possibly locking this out, but decided to let it ride.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Vlado
Vlado
Croatia
Show All Member Profiles
275,580 Are you busy
209,475 Re: Forum
196,866 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
