ShoutChat Box
Vibrator Supplies??
by gfretwell - 10/19/19 08:33 PM
FPE in Germany
by NORCAL - 10/16/19 08:24 AM
Help with aging employee advice.
by Bill Addiss - 10/15/19 10:58 PM
Fuse blower plug?
by gfretwell - 10/13/19 03:23 PM
Power factor and transformer efficiency
by TeslaEdison - 10/13/19 04:05 AM
FPE Breaker panel in germany
What is this for?
0 registered members (), 10 guests, and 12 spiders.
supplemental grounding #216614 01/05/16 01:35 AM
watersparkfalls Offline OP
OK I feel like I should know this off the top of my head, but I am drawing a blank. First question is simply "Can the supplemental grounding electrode conductor go from panel to first ground rod and from that first ground rod to the second in two separate pieces of wire?" In other words use 4 acorns and 2 separate pieces of wire. And secondly when installing a 400 amp service with 2 qty 200 amp panels can I run from the ground rods to the first panel and then unbroken to the second panel/ Or does each service require its own supplemental grounding conductor?
Thanks,
H20
2017 / 2014 NEC & Related Books and Study Guides
Re: supplemental grounding [Re: watersparkfalls] #216615 01/05/16 01:38 AM
gfretwell Offline
Yes, you can splice to a supplemental electrode
From the handbook
BTW does anyone see the anomaly in the code, demonstrated in the exhibit.
Re: supplemental grounding [Re: watersparkfalls] #216625 01/07/16 12:29 AM
Y
Yoopersup Offline
Ist you MUST make sure it is a supplemental Grounding Conductor not required by Code.
See 250.52./250.53/ 250.64
Splicing 250.64 C
Taping 250.64 D
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
cookcc
cookcc
California ,Long Beach
Show All Member Profiles
sparky 10
259,738 Are you busy
195,069 Re: Forum
184,476 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
