ShoutChat Box
Lock-down Thread
by BigB - 03/02/21 08:08 PM
Questioning the electrical norms
by Texas_Ranger - 03/02/21 05:21 PM
Northern Tool Recalls Powerhorse Generators
by Admin - 02/25/21 09:49 PM
You will never guess
by gfretwell - 02/25/21 07:48 PM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 34 guests, and 20 spiders.
Electrical mast flashing product #216394 12/04/15 10:30 AM
K
katwalatapan Offline OP
Hello,
I have a query concerning identify appropriate electrical mast flashing product for a renovation work. The roof and interior ceiling shown in the attached picture requires repair work due to water damage. It seems water is entering the area via the penetration in the roof where the electrical mast is installed. The electrical mast on the roof is installed very close to the wall and on the step flashing. This seems to be the area where water seems to penetrate and cause damage to the interior ceiling.
Is it recommended to re-locate the existing electrical mast to a location further away from the wall and then repair the roof and ceiling assembly, and then install an appropriate electrical mast flashing product OR Is it possible to repair the roof and ceiling while the electrical mast is still in place. Would an electrical mast flashing product be available for such an installation where the electrical mast is installed so close to the wall on the step flashing, because usually the flashing product would require few inches of clearance.
I'd appreciate your comments and recommendations.
Thank you.
Re: Electrical mast flashing product [Re: katwalatapan] #216395 12/04/15 11:17 AM
renosteinke Offline
I am not surprised there is a leak! There's nothing 'right' about that penetration. No competent roofer would attempt to 'flash' the penetration that way.
Yes, the mast should be spaced farther off the wall where it enters the lower roof. This means about 5" of clearance, minimum.
Yes, a proper 'boot' should be used. While electricians often use all-metal tapered boots, a boot with a rubber insert - as used by plumbers- is just fine. The boot needs to be slipped under the 'uphill' shingles and over the 'downhill' shingles. (This is a normal flashing detail).
No, you can't really do this without disconnecting the electrical service and re-working the mast.
But really ....
I'm not even sure that service meets your Power Company's requirements. They usually do not want ANY of the service mast concealed from view; they don't want someone to be able to tap in to the power before the meter.
I've never seen the service wires wrapped up as are those in the picture.
Likewise, I don't understand why there are two service masts present.
All these details make me suspect a service installed by an unqualified person, as well as many other 'improvements' to the building over the years - work that saw neither inspections nor professional work. Heaven alone knows what other violations are present (grounding?)
As Mike Holmes would say: Rip it all out. Do it over. Do it right.
Re: Electrical mast flashing product [Re: katwalatapan] #216398 12/04/15 11:44 AM
K
Thank you very much for your response. I agree with the incompentance on all parts of the work done and inspection conducted as well. This facility was built back in 1970s and handed over to us so very little we could have done.
The roofing detail was not done well, as it is evident with this problem.
The white service mast is for the communications service, which is not much of an issue, but the painted (brown) electrial service mast which penetrates the roof is an issue.
Re: Electrical mast flashing product [Re: katwalatapan] #216401 12/04/15 03:53 PM
HotLine1 Offline
Good afternoon:
As Reno said, there may be other issues with this.
Keep in mind that Reno and I are 'stateside', and use the NEC, and out area POCO rules. One of our Canadian members should jump in on this.
The service in the pic would be 'red tagged' IMHO, by me, as to why are the conductors wrapped?? Are they damaged from rubbing on the corner of the structure?
The mast/riser is considered 'inside the structure'. This may be the result of an addition to the structure, which enclosed the riser. Possibly this was an 'open' area between the two buildings?
Re: Electrical mast flashing product [Re: katwalatapan] #216403 12/05/15 04:26 AM
dougwells Offline
New MB and mast on the same side as the point of attachment. There isn't a flashing designed for that exsiting set up. I am going with that riser was on the outside of the building until they attached a shed to it smile also
Re: Electrical mast flashing product [Re: katwalatapan] #216411 12/05/15 08:23 PM
twh Offline
Where is the meter?
Re: Electrical mast flashing product [Re: katwalatapan] #216412 12/05/15 10:16 PM
HotLine1 Offline
$20 US says behind the door, before you get to the light bulb.
How about it katwalatapan, can you get a pic of the meter??
Re: Electrical mast flashing product [Re: katwalatapan] #216415 12/07/15 10:07 AM
K
Thank you everyone for your comments.
The service conductors from the mast terminate at the main disconnect switch in the shed/room. Then they are connected to the utility meter. The utility meter is installed as part of meter stack with other tenant meters.
Re: Electrical mast flashing product [Re: katwalatapan] #216416 12/07/15 11:05 AM
twh Offline
That isn't a mast so there are no "mast" products available. It's just a piece of conduit running through a roof. If it were a flat roof, a pitch pocket would be the solution.
Check with a roofer to see what they recommend. Maybe a flashing can be built to create a raised pocket into which a sealant can be poured.
Re: Electrical mast flashing product [Re: katwalatapan] #217640 09/22/16 02:14 AM
ThomasWinfrey Offline
Yeah, I agree with twh.
2020 National Electrical Code
Code (NEC)
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Admin
Admin
NY, USA
Show All Member Profiles
275,573 Are you busy
209,471 Re: Forum
196,859 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
