NEC- 314.23 (H) (1)
by GWEnergy - 08/07/22 10:40 AM
Wiring method choice
by gfretwell - 08/07/22 01:29 AM
Back From Retirement
by Bill Addiss - 08/05/22 07:39 PM
Load Calcs for EVs and RVs
by renosteinke - 08/04/22 07:34 PM
The "N" in the THHN/THWN
by HotLine1 - 08/03/22 04:06 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 25 guests, and 13 robots.
#214757 01/21/15 01:59 PM
What size breaker and what size cable should be used.
Sounds like 10ga/30a to me. What do the instructions say?
A lot of times they say 8ga/40a no matter what oven is installed.
4100 VA / 240V = 17.0833333- Amps
As Greg has mentioned, #8 THHN CU. protected by a 40 Amp 2 Pole Breaker is "The Norm".
--Scott (EE)
It would probably live forever on 12ga and 20a breaker, even with the timer and the light inside but you should still be sizing at 125% of the calculated current. That is how I got to 10ga/30a.
Yes they only call for a 20ga and 20amp breaker but we are going with a 10ga/30amp and sleep well...'
Thanks
Tools for Electricians
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
RonKipperDatacom
RonKipperDatacom
Kansas City, KS
BigB 3
294,638 Are you busy
226,406 Re: Forum
211,643 Need opinion
