ShoutChat Box
Do you count seconds?
by gfretwell - 12/05/19 07:36 PM
"Esoteric" countries and their wiring practices?
by Texas_Ranger - 12/02/19 10:52 AM
Look at this mess...
by NORCAL - 11/15/19 10:21 PM
FPE Breaker panel in germany
What is this for?
0 registered members (), 176 guests, and 11 spiders.
Hospital Circuit label for light switches #212878 02/25/14 12:44 PM
brother Offline OP
Is there a new code that requires a circuit label for hospital light switches. I can see the requirement for receptacles in Article 517, but I do not see it for light switches.
I was told this was something new that has been required.
Re: Hospital Circuit label for light switches [Re: brother] #212879 02/25/14 12:48 PM
ghost307 Offline
I can't find anything in the 2014 Code that requires circuit labels for switches; only receptacles.
Ghost307
Re: Hospital Circuit label for light switches [Re: brother] #212880 02/25/14 01:47 PM
brother Offline OP
Thanks for the quick response. even though it might be a good idea i couldn't find it in the 2014 either . Must be an urban myth awaiting to be born. :-)I have seen it in specs before as some hospitals.
Re: Hospital Circuit label for light switches [Re: brother] #212884 02/25/14 07:11 PM
HotLine1 Offline
I see nothing either. Sure it's not a 'spec'??
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Lostazhell
Lostazhell
Show All Member Profiles
Trumpy 1
261,186 Are you busy
196,325 Re: Forum
185,594 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
