ShoutChat Box
Danish type K Sockets
by dsk - 02/23/20 02:42 AM
15 amp outlets removed due to cell phones
by BigB - 02/20/20 07:23 PM
Square D "All-In-One" Panelboard
by gfretwell - 02/18/20 07:38 PM
2020 code
by shortcircuit - 02/11/20 04:30 PM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 66 guests, and 9 spiders.
Australia-wall boxes not required #212232 12/22/13 10:04 PM
newsgraphics Offline OP
Does anyone have any comments on the lack of code requirement for the use of wall boxes in Australia? I find it amazing that standard practice there is to use open-air mounting brackets attached to the framing to mount switches and outlets (powerpoints). In the event of a faulty connection, there will be nothing to contain arcing and/or fire and stop it from spreading into the wall cavity. I would think most electricians in the U.S. and Canada would consider this practice to be beyond dangerous. Also notice there are no metal plates being used to prevent drywall screws/nails from puncturing wiring! Amazing how two First World countries could differ on this.
Re: Australia-wall boxes not required [Re: newsgraphics] #212237 12/23/13 10:39 PM
Trumpy Offline
Personally,
I don't see what all the fuss is about. grin
This is the way that things have been done over here for some time.
We also don't have any more house fires caused by electricity than any other "First World country".
Sure you could use a full "flush-box", but the wiring in the bottom picture (although it should all be bought through the same hole in the dwang) would more than likely pass an electrical inspection.
With respect to nails getting put through cables, if you want to stay in the building trade down here for any length of time, you make damned sure that you keep your nails away from where the electrician has run his cable(s), this is why they invented things such as the ruler and the measuring tape.
Re: Australia-wall boxes not required [Re: newsgraphics] #212242 12/24/13 04:07 AM
Well, I guess you guys don't have to worry about being bothered with pesky things like calculating box-fill grin As to the need for nail plates, clearly you haven't encountered the workmanship of some of the slap-happy tract home "craftsmen" in the U.S.
Re: Australia-wall boxes not required [Re: newsgraphics] #212243 12/24/13 04:42 AM
sparkyinak Offline
Very interesting. Scary but interesting...
Re: Australia-wall boxes not required [Re: newsgraphics] #212245 12/24/13 05:28 PM
HotLine1 Offline
Trumpy:
Are you saying that you do not use any 'boxes' for your outlets??
We use items like the bracket in the pic for data/comm, and AV, and some other 'low voltage' items.
Re: Australia-wall boxes not required [Re: newsgraphics] #212246 12/24/13 07:43 PM
Few more photos I found online... Once again, no nail guards on studs. I wonder how many people in Aus/NZ have gotten a 240v "surprise" trying to hang a picture on the wall crazy
Re: Australia-wall boxes not required [Re: HotLine1] #212255 12/25/13 09:48 PM
Trumpy Offline
Hi John,
There are situations where you are required to use a "box" type mounting for electrical fittings on walls.
Things like dimmers or where there are extra connections at the fitting.
These sorts of mounting plates are used quite a bit these days because they are relatively cheap and fast to fit.
Personally I wouldn't be seen dead using one of them plates, as I've always been taught that wiring needs to be enclosed at fittings, irregardless of there being plasterboard on the wall or not.
newsgraphics,
Them dwangs you see in the pictures are installed at half wall height (4') to strengthen the studs, now unless you like your art down low on the wall, you'd usually be driving nails into a stud, would you not? grin
Besides, there are so many easier ways to hang pictures and things on walls these days without using nails.
One other thing needs to be said, down this way, we use 230-240V single phase, consequentially our wiring carries half the current of an equivalent 120V circuit and hence the wires are also smaller.
Our terminals at fittings are quite a bit different to the ones used in the US as well.
Instead of putting a wire under a screw, we have "tunnel type" terminals, these are very handy where you need to terminate more than 2 wires at a socket-outlet or light switch, it also means we don't need to "pig-tail" any of our wiring at fittings.
Provided the screws in the fittings are adequately tightened, loose or faulty connections are pretty rare.
Re: Australia-wall boxes not required [Re: newsgraphics] #212265 12/27/13 08:53 AM
wire_twister Offline
Trumpy,
Any way you could post a picture of one of the devices with the tunnel terminal on it?
Jimmy
Re: Australia-wall boxes not required [Re: newsgraphics] #212266 12/27/13 11:59 AM
gfretwell Offline
I bet the "tunnel" device is like the back of a good spec grade device or a GFCI here where you stick the wire in a hole and tighten the screw that tightens a plate on the wire.
Re: Australia-wall boxes not required [Re: newsgraphics] #212267 12/27/13 02:54 PM
geoff in UK Offline
Interesting to see the different terminology. Never heard of a "dwang" before. Here it would be a "noggin".
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Lostazhell
Lostazhell
Show All Member Profiles
dsk 6
djk 5
Admin 3
cgw 2
263,577 Are you busy
198,658 Re: Forum
187,553 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
