1 members (ale348),
302
14
What do you guys think? http://www.manufacturing.net/ple/index.asp?layout=articleWebzine&stt=000&articleid=CA270516&pubdate=1%2F1%2F2003
Scott
I especially like the idea of the funnel, since I work by myself most of the time. The masking tape probably would work, but I probably would have a screw drive or punch more handy than the masking tape
Yes. I like the funnel also, however make sure to first de-burr the ends of the pipe, so you don't have sharp edges when the ends get joined with a connector.
i like the idea of the funnel.an just fill the funnel up with wire pulling soap too.
Have used the masking tape, but not the funnel,great ideas.
kudo's on the funnel, probably worth $50 via 'idea's that work'
Good idea,
A flex spout or offset type would let it fit into a box.
Len
The funnel seems to be an OK idea, but if you're just concerned about damaging the wire why not just put a connector on the conduit?
Looks like a good idea, I will have to remeber that when working by myself
