0 members (), 224 guests, and 8 robots.
Previous Gallery
Next Gallery
#208870 02/16/13 06:05 PM
Free electric?
Nice tap
14 Comments
HotLine1 #208873 02/16/13 08:53 PM
Ha. Well at least it wasn't made to 220v
CZap #208909 02/20/13 11:39 PM
IDIOT !!!
YOU FORGOT THE GROUND WIRE !!!
grin
HotLine1 #208910 02/20/13 11:59 PM
But he has it taped up with green tape, so that should have it grounded good enough.... grin
Also it is a tamper resistant receptacle.
HotLine1 #208912 02/21/13 12:34 AM
That's a specification grade quality job....
Even as a temp power patch it makes zero sense.
Why not patch in after a 15Amp 120 C/B?
Why not patch in a GFCI receptacle?
Why not just run an extension cord -- for there has to be some receptacle within range.
How does one explain the break-in to the meter pan to the meter reader?
Why give up a clean path to the GEC?
Tesla
HotLine1 #208915 02/21/13 11:15 AM
This was found by a POCO troubleshooter who noticed the center cover off of the two meter pan. One of the meters was booted, and apparently someone needed 120 volt!
HotLine1 #208917 02/21/13 01:36 PM
If he had put this in a Bell box, piped out of that top hub KO, with a GFCI and an in use cover it may have survived for years.
HotLine1 #208918 02/21/13 01:54 PM
Hmmm, maybe there's a grow house nearby?
---Ed---
HotLine1 #208921 02/21/13 08:46 PM
Greg:
It may have survived...until either the meter guy, or a POCO 'drive by'!! They allow nothing from the meter pans/stacks.
The booted meter tenant is facing a theft of services charge. They pulled one leg boot off the meter for 1 hot leg in the apt.
HotLine1 #208954 02/23/13 02:59 PM
John,
I noticed that he cut open the center panel. Those old PSE&G locks were very difficult to break open.
