#207375 10/21/12 10:40 PM
My daughter recently purchased a house built in 1927. I just removed this outlet and no one in my area has ever seen one like it before. It was the only one like it in the house. I found the photo and information on Wikipedia of the similar 5 way outlet and am wondering if anyone has any additional information about this. The outlet is marked GE, 15 A 125 V, hasthe UL logo and appears to be polarized. The house has the original knob and tube wiring.
I would appreciate any additional information you would have on this outlet.
Thanks,
Gordon Green
[Linked Image from electrical-photos.com]
Admin #207392 10/24/12 01:43 PM
What is behind the five-way receptical cover plate?
thiggy #207394 10/24/12 03:19 PM
Don't know. that is the only photo of it on Wikipedia and the only copy about it.
Admin #207395 10/24/12 05:31 PM
Oops, I didn't read your OP carefully. I see now that you do not have the receptical itself, but posted a photo from Wiki.
Admin #207396 10/24/12 06:22 PM
Looks something similar to 'desbar' devices from back in the helper/apprentice days gone by.
Admin #207397 10/24/12 07:32 PM
Not quite - as far as I know, Despard devices were modular straps that accepted up to 3 devices on a 1-gang yoke.
Admin #207399 10/24/12 09:24 PM
Tex:
Yes, the 'newer' versions have 3 locations, as the receptacle devices are "U" ground. I was refering back when the receptacle was 2-prong, non-grounded.
Admin #207433 10/29/12 04:26 PM
John,
I remember seeing those despar devices. I also remember that they use to cram a lot of wires into small boxes. Then they would solder the splice, then use rubber and friction tape.
Admin #207506 11/02/12 02:50 AM
I took the photo of the 5 way outlet seen above, wa2ise asked me if he could use it on the wiki article and I obliged.. The outlet came out of an old 1928 house in East LA, CA that I did a partial rewire on. It's a Monowatt brand, it's all one piece unlike a Despard device.
thiggy #207565 11/06/12 06:08 PM
F
I have one of those. The "cover plate" and outlet are one.
The back is closed with plastic except for two screws. BTW There is one on Ebay right now
BBTW I have a duplex outlet that is clearly designed to flush mount WITHOUT a box.
Frank
