194
17
Getting ready to do a job that's going to have 6 ground rods according to code. 2 at the main service, 2 at (1) accessory building, 2 at another accessory building; all on the same residential property. Glad I've got my trusty rod driver on my roto drill:)
We have a ground rod attachment to our 90lb jackhammer.. Makes quick work of most of em...
Posts: 7,413 Likes: 9
Back in '05 had 705 rods for a major golf tournament. Air chip hammers, B&D Macho hammer drills, did the job. Used two towable compressors, 4 hoses each.
Fun part was to document the locations, and remove each and every one!
How did you get them back out? That's a lot of Rods lol
We had a 6" pc of 4" PVC cuts at each location, used orange spray paint, and documented each location on the site drawings. Removal was not really that bad, using the Lull forklifts, a web strap, and a Klien line grip (Chicage Grip) that nicely fit the 5/8" rods. Got them all out within a ten day total period of the teardown. About 50% were 'salvaged' to the event contractor for re-use somewhere else; the rest were mangled and trashed.
The complete teardown (electrical) was completed in 21 days.
I bought a Bosch electric demolition hammer way back when I was in business and I also bought a ground rod driver. It would drive the ground rods in with ease. In some of my towns. Where the ground was soft and/or had some rock. However where I live, it is almost all rock. It is almost impossible to get a ground rod down 8' every time, on the first try. You would have to stop and pull it out and try again and again. sometimes you would get it down 7' and you couldn't get it out anymore.
It's fun driving ground rods in shot rock and have it banana on you and have it come of the ground a couple feet away
