Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Power submeter connections
by HotLine1 - 01/19/23 09:09 AM
AFDD's coming to the UK
by Texas_Ranger - 01/17/23 07:22 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 20 guests, and 14 robots.
Anyone know of another vent cap that can be used in the soffit eave for bathroom exhaust fans other than the "big one" Lowes sells? They sell one that is for 4 or 6 inch duct. You have to cut at least a 6 or 7 inch hole just to use it for 4 inch duct. Just had a job that the soffit was only about 7 or 8 inch wide. The hole would almost take out the hole soffit. Surely there's another brand somewhere. I'm still looking. Thanks for the help.
Steve...
K
I’m not sure what the Lowes ones look like, but back in the day when there used to be new construction, I used a ton of the Lambro 4" under eaves vent caps. They are basically just a modified dryer vent cap and use the standard 4-1/2" hole. Sometimes if the eaves is a little too narrow, I'll pad it with a small block of 1X that I prime with BIN before I mount it, so it matches the white vent cap. I think Arlington also now makes blank plastic mounting blocks that can be used instead of 1X wood for this.
Lambro
I just happened to have this type on hand and the room for it, so I used one for the second floor bath on my own house. Same 4-1/2" hole, but a slightly larger footprint than the Lambro in the link above.
Deflecto
Please double-check your mechanical code. There are some restrictions placed on soffit venting of such fans. Code definitely is biased in favor of roof or wall venting.
Ditto to Renos statement above. You really don't want to do it twice!
Thanks for the link Kjay. The Lambro looks like what I am looking for, a simple 4" hole and nice looking vent. Reno, and John, in my area nothing is ever said about soffit venting. In fact that's the way the majority of them are done. Thanks..
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Scott35
Scott35
Anaheim, CA. USA
BigB 7
302,738 Are you busy
231,969 Re: Forum
216,687 Need opinion
