ShoutChat Box
Smoke & mirrors?
by JoeTestingEngr - 09/19/20 10:00 PM
Pool Lights?
by Papa - 09/18/20 05:26 PM
Ever been afflicted by Gout?
by mbhydro - 09/15/20 05:50 PM
Questioning the electrical norms
by gfretwell - 09/13/20 01:17 PM
120/208 gives 240? please clarify
by NORCAL - 09/13/20 01:08 AM
Facebook follies, bad wiring
FPE in Germany pt.2
0 registered members (), 12 guests, and 3 spiders.
Swimming pool water heater #205941 04/29/12 10:59 PM
MJ2000 Offline OP
Does swimming pool water heater need to be protected with
GFCI breaker (50A)?
The heater(heat pump) is more than 10' from the pool.
Thanks
Re: Swimming pool water heater [Re: MJ2000] #205951 04/30/12 10:43 PM
leland Offline
Mj.
In the States,the pool heater does not need to be GFCI. (2008- NEC) 680.9
680.26(6)(b). bonded and grounded per/instructions.
Re: Swimming pool water heater [Re: MJ2000] #205952 04/30/12 11:54 PM
MJ2000 Offline OP
Even if the code doesn't require a GFCI breaker, is it still worth the extra $100 for better protection?
Re: Swimming pool water heater [Re: MJ2000] #205953 05/01/12 11:09 AM
HotLine1 Offline
MJ:
IMHO, I would install GF protection. I don't have any CEC info for you.
An explanation of the benefits to the client, as opposed to the $$ for GF should help if the job costs are considered to be costly.
Re: Swimming pool water heater [Re: MJ2000] #205965 05/02/12 09:02 PM
mikesh Offline
Well the heater leaks current and a class A gfci won't even hold if the heater is large enough. Class b GF protection does not protect life so how can it work for life protection except that class b can be used where class a is not available? Actually look at rule 68-068 especially subrule 7
So if the heater is within 3 meters and not the other side of a wall then yes GFCI protection is required. If the heater is further than 3 meters then no.
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Vlado
Vlado
Croatia
Show All Member Profiles
Trumpy 8
NORCAL 3
269,932 Are you busy
204,359 Re: Forum
192,577 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
