Just wondering what everyone is doing on the big wood-frame commercial sites. Imagine 70 unit apartment building, 20+ framers, too many compressors and skilsaws to count. And add to all this -20 degree temperatures at lunch. Breakers just keep on going.
Like NESparky says, add more circuits, after someone agrees to pay you for it. If you installed the temp to the spec then it's not really your problem The framers could also get a gen, or a gas powered compressor. John
Temps can quickly get out of control. Always some subs coming in with something that's NIC And they want it hooked up free and by the way can you get it done now I got 10 guys who are waiting to work.
Now its time to barter, do they have something you need? You said big job, carpenters should have an all terrain forklift that could be helpful when you lighting or panels come in.
