One breaker only works when the dryer is running
by HotLine1 - 10/03/23 02:42 PM
Elk’s Lodge 11th hour ritual chime clock
by gfretwell - 10/01/23 02:06 AM
Strange breaker tip problem
by gfretwell - 09/25/23 08:13 PM
An impossible Support Violation
by gfretwell - 09/12/23 04:29 PM
How are you Jersey folks about the windmills?
by gfretwell - 09/08/23 02:21 PM
0 members (), 33 guests, and 11 robots.
#201346 05/28/11 10:46 PM
I was asked how to terminate a CU clad AL conductor? Do you use regular wire nuts or do you need the AL wire nuts?
Treat it just like aluminum wire.
F
Just run like standard alum conductor and just beaware with the rating they are simaiur to straight alum conductors as well { I know some peoples miss this one }
Merci,
Marc
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
renosteinke
renosteinke
Blue Collar Country
lemahj 3
311,332 Are you busy
237,652 Re: Forum
221,415 Need opinion
