1 members (ale348),
302
14
Posts: 7,381 Likes: 7
Another product surfaced Friday during inspections. Seems like there are a few mfgs jumping into the fray. This is a carry over from Harolds thread. Opinions, Gentlemen?? www.CMIwebsite.comhttp://www.cmiwebsite.com/html/pool___spa-electrical.html (Page to look)
Posts: 9,923 Likes: 32
You certainly want to go with the stainless one. It doesn't take much of a lapse on maintaining pool chemistry to have the water eat copper. Certainly that neglect you see in a "closed" pool will do it.
John,
I agree with Greg that I would use the SS one myself. It looks like these connections goes right onto the hoses from the pool filter, skimmer or return. I wonder if they will catch debris and clog up the line?
That is probably a good reason to put them downstream of the filter. Who installs this? Electrician or pool plumber?
That could be another topic!!!
I have to ask the ECs IF the water bond device is 'on them', or the pool guy.
Might be a good subject?
If I was the shop steward I would say the plumber puts in the fitting and the electrician hooks up the wire but I imagine the pool contractor does it all in most places.
Greg:
I'm going to try this in a new thread
what is this? ~S~
Another 680.26 (c) item to create 'stimulus' for a small business!
Using table 9 and guessing that is 8ga wire (.128" diameter) that would have to be almost 23" long to get the required 9 sq/in .128 x 3.14 x 23 = 9.244
