#192968 03/12/10 01:15 PM
Jim M Offline OP
Please check your Fluke non-contact detector to see if you are affected.
http://www.cpsc.gov/cpscpub/prerel/prhtml10/10164.html
Thanks Jim
Jim,
Thanks for the heads-up.
I use a Fluke NC tester (not that version, mine was made in the US).
I've had mine for about 10 years and as long as you keep the batteries fresh, there shouldn't really be a problem.
A note though to anyone that uses one of these sorts of testers (or voltage indicators in general)
Under any sort of safety regime, you should be testing these devices on a known source of voltage before and after you make any sort of test of the presence of voltage.
Minimise your risk of having an electrical accident.
Some people never live to tell of such things.
We all know (fortunately)not to depend our lives on these (I hope).
I have seen this recall passed around to several companies I service,for their techs and lab type people,who mey not know better.
So I'm glad it is out there.
I use the greenlee. I'm on about the 20th one- I loose things. frown
F
Merci, Jim for the head up with NCV tester but I have older verison so it is not affect with the recall.
But I will keep it in bookmark in case something do come up.
Merci,Marc
