Photo of the Week:
Old Fused Panel
 Old Fused Panel
>> Recent Posts
Parallel Conductors low voltage DC
by gfretwell - 09/06/24 01:37 PM
How's all our Non-US folks doing?
by grich - 09/04/24 11:10 AM
1 members (Scott35), 45 guests, and 38 robots.
#191197 12/21/09 06:22 AM
Found this on the internets today... thought you all might like it...
[Linked Image from iamalion.mine.nu]
Looks 'non-US' ??
Any clues
.....And we complain when we encounter old or sloppy work! I can't imagine being an electrician in Russia or wherever that is.
---Ed---
"Lucky shot, tavarich! 50 roubles says you can't throw this screwdriver into the other hole!" laugh
We had that picture once as part of a series if I remember correctly... the place burnt down, probably because of this "fuse replacement". These fuse holders are built like Edison base light sockets, but they have a porcelaine ring at the bottom of the element, so only a proper fuse with a narrow tip will fit (the diameter depends on the fuse rating). The bottom terminal is the line side, the outer thread is the load side. I can only assume someone wedged a metal object into the base and used the screw driver to both "secure it" in place and make the connection with the screw thread.
I can't find the original link though.
Tools for Electricians
2023 NEC + Exam Prep Study Guides Now Available!
The Watt Doctor
The Watt Doctor
Humble, TX
BigB 4
327,590 Are you busy
252,478 Re: Forum
235,122 Need opinion
