1 registered members (sabrown),
15
guests, and 21
spiders. |
Yet another odd plug
#190777
12/04/09 02:56 AM
This one was manufactured recently. Marking states 20A 125V. Pictured here with a 20A Hubbell outlet for reference.
Re: Yet another odd plug
[Re: wa2ise]
#190799
12/05/09 01:49 AM
Obviously wrong, since it would suggest the ground pin be on top...
[Re: noderaser]
#190801
12/05/09 04:31 AM
Obviously wrong, since it would suggest the ground pin be on top... i dont see an issue, canyou explain to me please
-Joe “then we'll glue em' then screw em'” -Tom Silva TOH
[Re: JoeKP]
#190828
12/07/09 04:37 PM
Interesting - a 20A plug that won't fit into a 20A outlet. It looks like it will only fit a 15/20A T-slot one. /mike
[Re: JoeKP]
#190837
12/07/09 10:39 PM
Obviously wrong, since it would suggest the ground pin be on top... i dont see an issue, canyou explain to me please Guess I was looking at it wrong...
[Re: n1ist]
#190839
12/08/09 01:59 AM
Interesting - a 20A plug that won't fit into a 20A outlet. It looks like it will only fit a 15/20A T-slot one. /mike It looks like it will fit, but the manufacturer has definitely chintzed on what should have been the T-blade.  Above=senior moment. Duh.
Last edited by Retired_Helper; 12/08/09 01:18 PM. Reason: Brain minus haze equals duh.
[Re: Retired_Helper]
#190934
12/11/09 09:20 PM
The problem is that while it will plug in to a US standard 5-20R, it will not plug into a Canadian standard 5-20R, which lacks the T slot, nor will it plug into a 5-15R.
The Canadian outlets are configured for 15A only, or 20A only, and not dual purpose 15/20A.
[Re: techie]
#190968
12/13/09 05:24 PM
The Canadian outlets are configured for 15A only, or 20A only, and not dual purpose 15/20A. Typical American me, I forgot about Canada.
#190981
12/14/09 12:33 AM
Just to make correction on Canadian outlets our 5-20r is a dual purpose outlet you can use 15 amp plug or a 20 amp T-lock also used in kitchens 20 amp GFI receptacle is allowed in stead of split receptacle cct. solves the problem of being too close to the sink 1.5 meters or 5 feet or less from the sink must be GFI protected
