Canada for the win
by gfretwell - 12/06/22 08:28 PM
Tiny Homes and the NEC
by gfretwell - 12/06/22 01:43 AM
EMC Glands on Motors
by Trumpy - 12/01/22 06:12 AM
Ground Rods: Installation and Hook-Up
by Trumpy - 12/01/22 05:54 AM
Happy Thanksgiving all!
by gfretwell - 11/30/22 05:55 PM
240/208 to a house
240/208 to a house
by wa2ise, October 9
Now you know.
Now you know.
by Tom_Horne, September 7
0 members (), 36 guests, and 12 robots.
#189511 10/12/09 05:16 PM
I have a job where the neutral and ground must be touching causing the GFI to trip. It's on outside lights. I was going to tie the lights themselves on the line side of the GFI and then tie the outlets on the load side, but if I hook the neutral up on the line side that feeds these lights, it trips the GFI. On the older models I don't think it mattered on the line side. I've taken the lights apart before and didn't see any "shorted out" neutral and
ground, so I'm assuming it's underground somewhere and inaccessible. Anyone ever had a problem similar to this? I guess I'll have to bring another circuit just for the outlets, so the GFI won't trip... Steve..
sparkync #189512 10/12/09 05:46 PM
K
It sounds like if your connecting the grounding conductors together in that box, then that is most likely the problem, since the fault will now be common to the neutrals on both the line and load side of the GFCI receptacle.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
JoeKP
JoeKP
Berkley, MA
Trumpy 6
NORCAL 3
300,608 Are you busy
230,284 Re: Forum
215,066 Need opinion
