Shout Box
Fuse blower plug?
by geoff in UK. 07/22/19 08:14 AM
Baseboard Mounted Light Bulb Socket
by SPSchuman. 07/15/19 03:22 PM
Hunter Fan Recalls Brunswick 3 & 4 Light Fans
by Admin. 07/11/19 11:08 AM
Honeywell Recalls some Smoke Sensors
by Admin. 07/11/19 11:03 AM
What is this for?
Plug terminals
1 registered members (IanR), 9 guests, and 10 spiders.
Removing BX marks from wall #189083
09/18/09 02:16 AM
09/18/09 02:16 AM
ahickey  Offline OP
Northern BC, Canada
Does anyone have any tricks/tips for removing the dark marks that BX cable leaves on a painted wall? I've tried the Magic Eraser in the past, but that usually messes up the paint finish. frown
Re: Removing BX marks from wall [Re: ahickey] #189086
09/18/09 02:25 PM
09/18/09 02:25 PM
Lostazhell  Offline
Bakersfield, CA (Originally Or...
I've used the Dottie hand wipes with moderate success in the past. Thinking about what's actually on the BX, (which is an oil) I might also try a bit of dish soap on a damp sponge.
whatever you try, test it out in an inconspicuous location on the wall first..
good luck =)
Re: Removing BX marks from wall [Re: Lostazhell] #189092
09/18/09 08:02 PM
09/18/09 08:02 PM
electure  Offline
Fullerton, CA USA
I, like Lostazhell iagree , have used dish soap or liquid hand soap with wet paper towels to get that stuff off. Be sure to rinse the wall when you're done to get rid of the soap, and dry it off. (it takes a lot of paper towels)
Re: Removing BX marks from wall [Re: electure] #189098
09/19/09 05:40 AM
09/19/09 05:40 AM
Alan Belson  Offline
Mayenne N. France
Why do the makers put the oil on it to start with?
Re: Removing BX marks from wall [Re: Alan Belson] #189099
09/19/09 11:08 AM
09/19/09 11:08 AM
JoeTestingEngr  Offline
Chicago, Il.
I'm not saying that this works BUT I'm amazed at all the things that WD-40 takes off. I just showed someone how well it works on what's left after you remove a price sticker. It would be interesting to see how it works with BX coating on a painted surface. I do remember ruining a silver embroidered skydiving windbreaker by carrying a roll of BX. That was an expensive lesson.
Joe
Re: Removing BX marks from wall [Re: Alan Belson] #189101
09/19/09 11:31 AM
09/19/09 11:31 AM
mbhydro  Offline
Winnipeg MB Canada
I wonder if its oiled to keep it from rusting while its in storage, sort of like sheet metal for heating ducts have a coating on it when you buy it at the store.
Re: Removing BX marks from wall [Re: mbhydro] #189102
09/19/09 12:32 PM
09/19/09 12:32 PM
Tom  Offline
Shinnston, WV USA
I think the oil is most likely used to lubricate the dies that form the armor. Aluminum jacketed MC can be worse as it seems to contain graphite.
I think the best thing to do is avoid the problem in the first place by leaving a roll of the cable out in the weather for a month or so & let mother nature wash it off for you.
Re: Removing BX marks from wall [Re: Tom] #189105
09/19/09 01:44 PM
09/19/09 01:44 PM
renosteinke  Offline
Blue Collar Country
Well, Tom, I'll give you half credit. laugh
Nearly all AC, MC, FMC used today has an outer jacket made fron aluminum. I agree that the oil is there as part of the manufacturering process.
Aluminum does, in fact, react with air. This results in a layer of aluminum oxide (think 'aluminum rust' so to speak)forming on the surface of the aluminum. While this layer doesn't flake of as real rust flakes off of iron, it does come off fairly easily. The acids in your sweat combine with aluminum, which is why your hands get so black when you work with MC.
Now .... think for a moment .... what do you get when you mix fine colored particles witha light oil? We have a special word for this mix. We call it 'paint.'
So, in handling the MC we make what amounts to a black paint- which then rubs off onto the wall. Remove the oil, and the black stuff - aluminum oxide- remains.
Unless the surface is completely smooth and non-porous, you're stuck with having to cover your marks with more paint- paint that matches the wall this time.
Re: Removing BX marks from wall [Re: ahickey] #189118
09/20/09 07:11 PM
09/20/09 07:11 PM
Niko  Offline
Campbell, CA
I have been using simple green with great success for most of my cleaning for me it works great. i use wd-40 to remove tar.
Edward
Re: Removing BX marks from wall [Re: Niko] #189147
09/21/09 11:54 PM
09/21/09 11:54 PM
K
KJay  Offline
MA, USA
I always carry a spray bottle of ZEP glass cleaner mix and a roll of white paper towels. I mix the ZEP myself from concentrate and like to make it a little strong, so it will remove oils like that MC gook and oxide, but not so strong that it takes latex paint off walls.
I use it for cleaning just about everything. Every light fixture and wall plate gets cleaned after installation when I do the finish on a new house.
Watch out for those paper towels with the color prints on them though. That print color stuff [Soy ink??] comes of on the walls and leaves a nasty stain that is extremely difficult to remove.
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Theelectrikid
Theelectrikid
Levittown, PA
Show All Member Profiles
Admin 5
UTEE87 1
257,193 Are you busy
192,997 Re: Forum
182,667 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.6.1
(Release build 20180101)
Page Time: 0.028s Queries: 16 (0.003s) Memory: 1.0273 MB (Peak: 1.2103 MB) Zlib enabled. Server Time: 2019-07-22 15:01:22 UTC
