by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
NORCAL Offline OP
This was the way I got this mess. Any comments welcomed.
Looks safe enough from this side of the country! Hey, at least they connected the ground wire so they were somewhat safety-conscious.
---Ed---
Whats the hazard? aside from the install.
Even I would have put in a box.Or at least some 33!!!!
Cheap basta*&s.
NORCAL Offline OP
That TEK "grounding" screw is another problem too. crazy
Why has it got seven wires going into it? confused Why is it parked on the tailgate of a truck? confused
Well, at least they attempted to scrape the paint off from under that self-tapping ground screw. smile
NORCAL Offline OP
Why is it parked on the tailgate? Because I wanted the motors, that's why. whistle
BTW the TEK screw is not a kosher method of grounding.
Y
What Class & Division??
If it werent United States I'd say wye/delta three phase and thermal protection (though 8 wires seemed more likely in that context).
NORCAL Offline OP
The motor is 1 HP 1Ø, rated for 115/208-230V.
F
Did the fan came off from the spray booth area ? if so they are freaking nuts.
Merci,Marc
