Using THWN on automotive circuits
by BigB - 03/21/23 07:52 PM
Continuous load
by HotLine1 - 03/08/23 02:11 PM
How's all our Non-US folks doing?
by dsk - 03/08/23 11:56 AM
Old Computers?
by Bill Addiss - 03/04/23 05:06 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 24 guests, and 15 robots.
Y
This area would come under (517.1) to the Extent that Backup lighting Would be required only.
Exercise Equipment mostly ,
No life support systems .No reduntant grounding required.
How do the rest read it??
2020 NEC & Related Reference & Study Guides
Pass Your Exam the FIRST TIME with these Exam Prep Combos:
>> Master Electrician Exam Prep     >> JourneyMan Electrician Exam Prep
A little more info, please.
I am sure your building code requires sufficient backup lighting for egress. I doubt you need to bring this up to the level of "task lighting" although the task of working out on an elliptical machine is not that sight oriented.
What is the issue?
I don't think it falls under 517. I've see this type of occupancy where they have physical therapy for sports injuries. I don't think backup lighting is specified in the NEC. Check with the Building Official or the plans as reviewed. Also the Fire Marshall might have some input. If are going to use 517, then every work out room and gym would be subject to 517. Check the Plans.
George Little
Y
This area is for Hospital related recovery injuries.
After surgery & such. Prescried by a doctor .
A person may be Handicaped & require help.
Thats why I feel it requres.
#1 Exit lights As most Buildings.
#2 Task lighting. (Enought to get off the Machines Ect & safely exit the Building).
It is I feel Heath Care Related not like a Sports or Standard Gym area.
READ 517.1 Scope. BUT I could be wrong! woundn't be the ist time Nor well it be the last.
Yop:
Egress lighting (Article 700.16) locations/placement & requirements is a Bldg/Fire item here in NJ. The Elec AHJ is responsible for wiring and circuitry.
What do the plans call for??
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
pcsailor
pcsailor
Minneapolis, MN, USA
triple 2
dsk 1
304,924 Are you busy
233,346 Re: Forum
218,068 Need opinion
