Underground phone and coax depth?
by libellis - 02/08/23 02:21 PM
Al Hildenbrand - Minneapolis - obituary
by Bill Addiss - 02/03/23 07:38 PM
Violation?
by renosteinke - 01/27/23 09:52 PM
Does NEC 551.71 (F) apply to dwellings?
by BigB - 01/20/23 10:46 AM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
1 members (Scott35), 14 guests, and 13 robots.
Mike,
This is not some half-baked backyard effort.
We're talking about a trailer that gets pulled by a Kenworth truck, and it has its own rego, COF etc. 3 axles at each end with dual wheels at each end of each axle. The existing plank decking is to be replaced, and some additional load-bearing beams are being added to increase the weight-carrying capacity.
It is a requirement for a COF that the structural welding is done by a certified welder. My friend does have that qualification, as does the helper that he will be employing to assist with the refit. I understand that drawings of what is going to be done have been prepared and run past a transport engineer so he can be certain that what he is proposing will pass certification. The finished trailer will be put through the proper testing so it can be legally used on the road, it would be a bit pointless to do a project like this and not make it road-legal!
Later,
Mark
Mark aka Paulus
Mark,
What an interesting thing you've dug up.
I fix welders at work and when you consider that MIG welders are pretty easy on the supply, when used with an Argo-shield gas and non-fluxed wire, they don't tend to upset the supply all that much.
However, when you start using a MIG with flux-cored wire (as in no shielding gas) the welder has to work that much harder, as the welder has no gas to cool the liner towards the torch, this causes friction.
Your current will increase, accordingly.
Liner failures are common with gas-less MIG welding.
And that is only with steel, other metals like stainless or aluminium are an acquired taste.
But then again, if you can TIG weld aluminium is easy to weld.
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
watersparkfalls
watersparkfalls
Washington...Not DC
BigB 2
303,295 Are you busy
232,253 Re: Forum
217,014 Need opinion
